Parking Brake Levers - 1972 K10
I am looking for Parking Brake Levers, that go in the drums, behind the brake shoe that the parking brake cable hooks into on the driver and passenger side for a 1972 K10. I understand that they are a different shape from 1973 and up
I also need the Pin and clips that hold them to the brake shoe. Maybe one of you all will at least have part numbers for me to try and find? |
Re: Parking Brake Levers - 1972 K10
Have you checked rock auto? or NAPA?
squarebody parts will work, if they come from the 2 3/4” wide shoes they will also work but you will have to flatten out the parking brake lever a little bit Because it connects in the approx center of the wider shoe.
Hi guys, i found them at 4wheelparts.com, and i found the clips that hold them to the brake shoe at Napa. Thank you so much for all your help. As usual.
