1973 C20 2wd build thread
4 Attachment(s)
This is my build thread for my 1973 C20
2wd 454/th400 4:10 14 bolt posi |
Re: 1973 C20 2wd build thread
Added some LED Tail lights and LED Side Marker Lights
Will update as I add parts as this is my #1 project for the next few months |
LED they are yellow not amber. I will try to get used to them
Added Aluminum radiator and electric fans. Ebay kit not bad for $200
what radiator kit did you buy?
G force trans crossmember with new trans mount installed to tuck new exhaust coming soon above the frame rails.
2 Attachment(s)
New Grant steering wheel. (stock is worn and sticky) $160
New 33 inch tilt column 2 inches shorter then stock i believe so gear shifts are tight and precise and more room inside the cabin. $280 |
Big Block Chevelle Longtubes are next (do not hang below the frame rails) new 3 inch exhaust with x pipe and Magnaflows. Have 3 inch Flowmaster 50's on the truck now but need more clearance and the Flowmasters are robbing power.
