What did you get done this week weekend 12/8 edition
2 Attachment(s)
I had a guy wrap my old cracked dash in red vynal and that came back and installed also laid in the carpet on the 76 and all the trim that goes along with that removed the headliner to replace the fabric, and got in to the horn fiasco on the 79 Sooner or later ill get that truck to be able to be inspected.Pictures will come later
How about you all |
Re: What did you get done this week weekend 12/8 edition
Replaced and bled the clutch master and slave cylinders today after replacing the clutch a couple of weeks ago. Bleeding was a challenge. Bought a mityvac. No go. Finally pulled it all out and bled it on the bench as a unit.
Dash looks nice! Look forward to pics when its installed.
I am torn between doing the DIY repair and repaint or having it wrapped like you did. |
Replaced both front brake lines and the back half of the rear brake line, also all the rubber fuel lines which look like they could of been original. Started reworking my exhaust since the 2wd y pipe won't work with the transfer case and front drive shaft.
Got new tires mounted! (on the wheels, truck isn't ready for them yet)
Replaced 2 of my fan belts, got my "new" spare rim repainted as well as the tailgate that came with my truck
