3 Point Belt Help
Hi
New to me 70 C10. Inside cab was painted before my tenure. Upper B Pillar hole barely visible https://pbase.com/robpp/image/170460135/medium.jpg I stuck one of those remote scopes up the inner B pillar and here are some pictures. I assume this is the upper seat belt mount? https://pbase.com/robpp/image/170460141/medium.jpg https://pbase.com/robpp/image/170460138/medium.jpg |
Re: 3 Point Belt Help
If memory serves, that is just a plastic plug on the inside of the cab screwed into the recessed mounting point.
The top bolt for the shoulder belt includes the special bolt that attaches to the mounting point. Someone else may chime in..... |
Drill into the center, see if it's been bondo'd or welded closed.
You got it....I had the plastic plug in mine before I installed 3 point belts.
It was an easy bolt in. |
That's it, looks to be full of bondo, shouldn't be a huge task to clean out the threads. Trevor
Yes mine had plastic cover in it. Somebody may have bondo it up though you never know. The nut is been in every truck I have ever seen though. All three of mine have them.:chevy:
I think it 7/16 fine thread but will confirm before I do anything. ' am thinking the tap if I can get it started . i have some thread chaser set too. Thanks |
Does anyone know if these bolts for the three point can be purchased aftermarket? The genius that worked on the cab before I purchsed my 70 decided that some sweet stereo speakers would fit better in that location...I will be filling in the holes and wanted to re-mount a nut to install seat belts.
Is there any other support that should exist inside the cab channel for the seat belt? |
I have no idea but would think a nice size washer would add some strength to the wall. As far as mine I buy a grade 8 bolt and use them. Fine thread but don't remember the size right off.:chevy:
3 point belt come with the bolt in upper attachment mount and yes it’s fine thread .
Just installed mine . |
That's a good idea. Anything else I'd be missing?
you would want a cage nut, google it
My .02 is that I wouldn't be comfortable with just welding a patch in with a captive nut would not be strong enough.
Here's what I would do. Cut a piece of 1 1/2"? x 1/4" flat stock about 3" longer than the hole is in diameter. Weld a 7/16" nut to the back side of the flat stock and then drill back thru the nut into flat stock the hole correct drill size so you can tap the flat stock the same as the welded nut. Then center the flat stock in the existing (1 1/2") on either side of the big hole. Drill a couple of holes on either side so you can plug weld the flat stock in place. Now you have reinforced the mount just not the welding of the big hole. Then just make a patch to cover up the big hole. Just my .02. |
That was my original plan, hence the reason I was asking about any additional stock reinforcement besides just the cage nut welded onto the backside of the cab sheetmetal. It doesn't seem strong enough to hold the potentially violent motion of a seat belt pull.
Boy am I lucky no one screwed up my interior sheet metal. Dash is not cut, no crappy speakers in doors or kick panels, and no gun rack holes either...:metal:
