Step for my '72 Blazer 4x4
I'm sure this may have been discussed before, but I'm wanting to install some steps on my '72 Blazer 4x4. I do not want to install full nerf bars. I'm sure someone has done these before. Where is the best place to get these and what do I mount them to?
Re: Step for my '72 Blazer 4x4
2 Attachment(s)
Found mine cheap, so I used them (first pic). Wish I could find some like the second pic. Mounted to the rocker box. Both are the Carr aluminum steps.
Hemi do you have more pics? both up close and further away to see the whole truck?
2 Attachment(s)
honestly never been a big step fan on these trucks (no offense to anyone that likes them) but I think yours may be my favorite. Much lower profile and less obnoxious than others i've seen.
I used Bully bolted to the torque boxes. Small but work.
https://www.summitracing.com/parts/p...oaAujWEALw_wcB |
Mike Cofield reproduced the K5 GM accessory steps - maybe he has some left? An open loop scares me in that if you slipped and wedged your leg inside of it that both bone tib-fib fracture would hurt bad and dangling there waiting to be extracted would be excruciatingly long.
Mike Cofield is on instagram
https://www.instagram.com/mcofield1967/?hl=en |
Hickey folding steps are nice
Posted via Mobile Device |
2 Attachment(s)
Thanks for all the replies guys. I think I've got enough info to make a decision on.
Take the rear torque box cover off and use long arms to reach in to either drop bolts with washers in the holes you drilled or vice versa. The Bully steps have one hole drilled for a bolt and another for a smaller self tapping metal screw for each mount. I redrilled for bolts and used large washers inside the torque boxed to spread the load. I like Hemi 43’s fabricated steps-pretty heavy duty. I also like the GM accessory type but the Bully sufficed for me. If my wife didn’t need the step to get in, I wouldn’t have any.
Originally Posted by CamTra View Post How hard is it to access the top of that rocker box? Like rsavage suggested, I unbolted the rear torque box cover for access. This might be difficult if yours are original though. __________________ The one that dies with the most tools, wins ! Thanks guys. I appreciate the info!! |
