Power Steering Fitting Question...
Did a search, nothing conclusive.
Has anyone had luck converting high pressure side of 80's model steering box fittings to -AN? Want to lose the factory hose/hard line and go straight to -6AN to 18MM o-ring. See link below for fitting. Pretty sure it will work, was just wondering if any of the membership had already done this? The fitting... https://www.jegs.com/i/KRC/612/10123000/10002/-1 Thanks in advance, T, |
Re: Power Steering Fitting Question...
I always use -6 line and used a fitting like that. Double check that the two ports are same size on the box. Use the high type Teflon lined -6 line on the pressure side.
Thanks for the help... T, |
