WTB Suburban Doors
Does any body have a nice set of Suburban barn doors they could part with?
Re: WTB Suburban Doors
Still looking for some? Are you looking for just the doors or complete with hinges and slide mechanisms?
I have an extra set of doors that are rust free. There is some filler on the drivers side door. The insides are very nice. Let me see if I have all the slide mechanisms. Might take me a day or two to drag it all out and make sure it’s complete. I also have metal cuts where the lower latch plates are located as well as the upper latches and slide mounting points. I’ll try to locate it all tomorrow and send some pics once I have it all together.
Bryce |
2 Attachment(s)
Here is a pic of the doors and the metal cuts along with the slides and catches. I will need to keep the door handle and tinted glass for the doors. I have a set of clear glass that can go with them as well. I’ll send more detailed pics of the doors
2 Attachment(s)
Inside of doors
2 Attachment(s)
Underside of doors
4 Attachment(s)
Let me know if there is anything else that you want pics of. The lock will not go with them as well since I need them for my other doors but I may have one that needs a key made.
PM sent
Send Richard2717 a pm. He has a mint set of rust free 72 barn doors he got off my crew cab donor suburban. I believe he listed them on here awhile back not sure if still available...
Posted via Mobile Device |
i have a complete set of barn doors in northern colorado but freight would kill ya
It is easier to switch from tail gate to barn than the other way around. All the slots for either setup are there from the factory for the hinges except for the lower sill. Your main difference is in the lower sill. Barn doors will work fine with a tailgate sill, you just have to fill in the holes where the gate hinges went thru. The barn door lower sill does not have the recess and slots for the tailgate hinges. your catches that bolt to the body that keep the gate and hatch closed are the same as the ones for the barn doors, just relocate them to the upper and lower sills as needed. Richard |
Thanks, Richard. After I advertised I realized I had no idea if it was simple. Good information.
