Bed cross sills
Does anyone have pictures of where the cross sills are mounted and is the front sill mounted to the front bed panel and how?
Re: Bed cross sills
This diagram on the Mar-K site should explain it pretty close http://www.mar-k.com/Catalog/index.aspx?CID=10001
Re: Bed cross sills
Thank you
Re: Bed cross sills
You are going to want this one before you are done http://www.mar-k.com/_assets/images/...nformation.pdf
You might need to dig out your old Crackerjacks secret decoder ring to figure it out though. If you have the stock frame the appropriate holes in the frame will tell you where the bolts and pads go. |
Re: Bed cross sills
Thank you Mr 48chevy that helps a lot. The frame is a Fatman after market so i will see how it all lines up. Do you know if the front sill bolts to the front bed panel?
