Steering column questions
Hey folks. Will a 67-72 tilt column bolt into a 1982 Crew Cab ? Are they the same length ? The goal is to eliminate the key on the column. Is there an easier way to do this. Ideally the column would be a floor-shift, tilt column. Thanks. Brad Moore.
Re: Steering column questions
I would think you would need a van column of 1974 up with a dash mounted key...
82 and older van columns are the same as a 67-72 basically. they won't bolt into your truck either I don't think. my 76 van one wont for sure.
You maybe able to change the 82 Van upper section of the columns. On to your column but you will need with the same option. It's been a long time now since I see the van 81-82 columns if the set up sizes in upper tilt the same it may work. But I think the Vans columns come with the shift indicator on the columns it can remove re-work that area
it would look like it was factory. Then you could go with key on the dash or push button start. This may help try your conversion https://bowtieguy.proboards.com/thre...r-repair-renew |
This is the Shift lever Housing (pic of this part is A/T, you would need a >( M/T ) one.)
This way you get rid of the hump for the shift lever. |
What about just modifying the column you have now?
Pull it apart, and remove the key/locking section. Otherwise you may lock up at a very annoying time. Cut the key bump out of the column, and epoxy a piece of sheet metal behind it. Then fill the divet in with fiberglass bonds or JB weld. Sand, and paint. Move key to dash, and enjoy. |
...and enjoy. Hahaha! |
Absolutely right ! That is the new plan. Rebuild the inside, modify the outside. Thanks to everyone for the input.
