Needing some info on bucket seats
4 Attachment(s)
So I’m scouring the junk yard trying to find a set of low back bucket seats from a blazer for my 69 c10 (because I know for sure the 73-77 buckets will work and I’m too cheap to pay the price tag of the 69-72 seats) but good luck trying to find the low backs in a junk yard right?
Are the high back seat frames the same as the 73-77 low back frames with the exception of the round bar welded toward the top of the frame? I found an 83 blazer that has factory buckets and want to know if I can cut the round bar off and use them in the 69.... also what years were the high backs made like this? Mid 77 to when??? Posted via Mobile Device |
Re: Needing some info on bucket seats
I would check out the 69 blazer forum or what ever your looking for. I did see some posts or threads in the the last couple days of chopping high back buckets but wasn,t what I was looking for so never read them
Just get them and take backs off and cut em. Try to preserve foam so you dont have to buy new foam. Cause foam is expensive also. Am trying to put low back seats in my 75 pickup also. Have some high backs already may just cut them down and see what I come up with also. Worst case scenario I ruin seats. Or have to make a plate underside to match up bolt pattern with frame where seats bolt to. Since you have the frames bare can you see if mounting holes on underside match up. I have some low back seats from a 73 that are down to frames but foam now is 200 per seat. Let me know what you figure out. Was going to buy some low backs off of facebook but by the time they got here would be 900$. And I cant see that for just my daily driver. Also needing mounts. Am looking into Corbeau seats for frame. There low backs start around 500 a set with new foam and choice of colors. Need to do more research though.
