What is this "connector" actually called?
Re: What is this "connector" actually called?
GM 12191376 Battery Positive Cable Junction Block. Looks pretty nifty. For recent model years. You can google for it and find a bunch of different sources to buy from. https://www.google.com/search?q=GM+1...junction+block
I don't know about a source for the weird L-shaped terminal that crimps onto the cable. |
https://www.amazon.com/Genuine-GM-12.../dp/B000QIQUE6
https://www.ebay.com/itm/25363518264...gaApXiEALw_wcB https://images-na.ssl-images-amazon...._AC_UL115_.jpg Doesn't come with the connector. looks to be some kind of "flag terminal" , Maybe it has a GM part number and could be sourced from the stealership? Standard flag terminal looks like it would probably work fine. |
[QUOTE=dmjlambert;
I don't know about a source for the weird L-shaped terminal that crimps onto the cable.[/QUOTE] Thanks, but that L shaped terminal is the part I need, not the box. I am just looking to join the wire from the alternator to the positive battery cable for my LS swap. I will look into the flag terminal that Greasey Harley mentioned. Thanks. |
Why not use this. It looks pretty close to the same thing just run them straigt out.:chevy:
https://www.summitracing.com/parts/c...kaAlFjEALw_wcB https://static.summitracing.com/glob....jpg?rep=False https://static.summitracing.com/glob....jpg?rep=False https://www.summitracing.com/parts/s...gaAlkrEALw_wcB https://static.summitracing.com/glob....jpg?rep=False |
If you can’t find the flag terminal, I have an extra cable with the fitting you need that needs a new end crimped on... you can have it if you’d like it. |
Thanks for your reply! |
https://ceautoelectricsupply.com/ind...style-eyelets/
unfortunately shows out of stock... but maybe more searching using some of those key words will help you find it |
