Pre-Finished BedWoodŽ
Check out the 100% Pre-cut, pre-drilled (for the bed-to-frame and perimeter bolts) and Pre-finished using our H2X system.
Here is a link to see an install of one https://www.youtube.com/watch?v=KGh23z5kGYQ |
Re: Pre-Finished BedWoodŽ
Are all your beds prefinished? Can you do hidden bolt holes from underneath or custom holes? I am not using one of the bed to frame bolt holes on each side because my rear gas tank is in the way of one bolt and would not need those 2 holes. Thanks
Can you just buy the wood prefinished? I already have the stainless strips and bolts. Do you prefinish the exotic types as well or just oak and pine?
Yes you can buy just the wood pre-finished. We will do any of our species in your choice of our Satin H2X finish or our High Gloss EZ Seal and Shine!
Give us a call 877-206-9663 for your Free Quote |
Not all of our bed are pre-finished. You can select undrilled for your hidden bed-to-frame bolt application. Give us a call for all the options that we have. 877-206-9663
