Help with front fender and grill removal
3 Attachment(s)
I am getting ready to do my inner rockers and floor pans and wanted to remove my front fenders also along with the grill and bumper. I have managed to get most of the passenger side fender loose but something is holding it up in the front. I removed the very difficult 1/2 bolts that were tied into the radiator support and a couple others. I thought maybe it was catching on my bumper so I tried to remove it but there are 2 bolts on the top.of the bumper that I can not get access to unless the grill is removed. You can see in the picture that because of the angle no socket or wrench will fit . Any help would be great. I have read a bunch of different links on this forum about it and tried to follow the recommendation of the bolt removal sequence. I have removed all of the ones suggested but still just can get it off. Thanks.
Re: Help with front fender and grill removal
[QUOTE=Getter-Done;8876623]Can you get the other bolt on the bracket loose?
Yes sir, inwas able to pull all the lower bolts on the bumper, took them all off but cant get access to the two upper bolts unless the grill comes out. I think |
