HG's Plow Truck, '78 GMC K35 Dually
4 Attachment(s)
Last year I decided it was time to retire my old plow truck, a 76 K10. I bought it when I bought my house because we are out in the corn fields, in Minnesota, and I have a 1/4 mile long driveway. Plus a big area around the house and garages and sheds that needs to be cleared out when it snows. It was my first snow plow and for the most part it did the job. It really struggled late in the winter when the drifts and piles were big. It didn't always start easy but was okay once it fired up. The wipers worked occasionally, which is a joy when you're pushing a path on a windy day and it's blasting over the hood. It was extremely rusty. But like I said, it did the job most of the time. Until the transmission also started to fail. I used it for more than a year with only low and reverse. It had a TH350.
Anyway, I wanted something better and was shopping for a cheap early 2000s silverado. The EFI and LS motor was a plus. But the cheap ones I looked at all had frame rust or cracks or both. Then this 78 GMC K35 dually came up on FB only 25 miles away. Rebuilt motor, missing the rear dual wheels and with the wrong front axle. Someone swapped out the dually style Dana 60 for a big hub Dana 44. But it was pretty straight and the rust wasn't what I would call terrible. Not for this area. So I went to check it out. It had been for sale for over a week and the seller was still running it from a little push mower gas tank gravity feeding the carb. ???? Okay, it started. The guy said it had been sitting a couple years and the gas in the tank was bad. I told him I wouldn't even make an offer unless I could test drive it. I asked what we had to do to get it driveable and he said we just had to get the old gas out and put new gas in. I said let's do it. We went to the gas station and filled a jug then ran the engine off the lawn mower tank while the fuel pump sucked the old gas into a bucket. It only took a minute. Put fresh gas in, hooked the pump outlet back to the carb and away I went! Grabby brakes, but they worked. 4wd worked. It didn't seem to be over heating and sounded like it was running good. Oh yeah, no gage cluster. Another bonus was that it had a plow mount but not the blade. The hydraulics had been rebuilt and most of it was powder coated and looked great. And my current plow blade would fit it, same brand and model. We worked out a deal. $2200 which I think was fair but not exactly a steal with things like the wrong front axle, missing cluster, tires, etc. But it had potential which was something the old plow truck didn't have. Let's see if I can find the pics from when I bought it. |
Re: HG's Plow Truck, '78 GMC K35 Dually
3 Attachment(s)
I bought it and drove it the 25 miles home. The only problem along the way was when I stopped to get more gas and it was dumping fuel on the ground. The fill hose had a big hole in it so I pulled it off and put gas directly into the tank inlet. When I got home I checked the temperature of the hubs and I joints. The rear u joint was hot.
Oh and the seller had the original 16.5" wheels. The truck had 16" wheels on it and he had the full set. And he gave me a cluster but it was kinda crappy. |
3 Attachment(s)
There were a few things that needed to be done soon because I really didn't like the look of it with the topper and missing duals. I replaced the bad u joint and the gas filler hose. Found a better cluster in my parts pile. Found out the speedometer cable was shot and replaced that. Gave the topper to a buddy. Ordered some tires and got a pair of wheels powder coated then mounted them up. I made sure my blade fit the plow mount. And it wasn't set up for turning the blade side to side so I added the hydraulic hoses for that to work. And I replaced the cab running lights because they were toast. Luckily I didn't find a bunch of rust in the roof from leaking lights. The new LEDs were a nice upgrade.
5 Attachment(s)
There was so many things to fix. And so little time. I was shut down from work with covid so I did have time but we have a short summer and winter never seems far away. The windshield was cracked and I really wanted to fix that so I ordered one and a new gasket. I never replaced one on a square before. It's different from the older style but after a few tries with the tool to get the locking strip in it went okay. But that part came after I had to fix rust in the windshield post. There's a blob of some adhesive or something in the middle of the post. It completely blocked it off so water leaking in from the busted running lights sat in there and it rusted from the inside out. I found one in the junkyard to cut out for a patch and did another rust repair for the first time.
4 Attachment(s)
More pics. BTW, this is kind of a pain in the rear. I also removed the rear section of the running boards. They were corroded and I don't like them anyway.
Cool pickup. Having revived a MN pickup with a plow, I can appreciate the work involved.
Cool rehab!
Bet with some weight in the bed age is going to plow well. |
You grabbed a good one. And immediately improved it dramatically. That thing is a beast and will be worth taking good care of.
5 Attachment(s)
The next upgrade was to the interior. I wanted it to be nice, comfortable and have everything function. I was able to get most of that accomplished but it really turned into a much bigger project than anticipated. I wanted bucket seats and a console. It needed a radio. It's an AC truck but that wasn't a priority, heat was definitely a priority. While I am mostly happy with the results there are still some things to work out but I'll get to that later. I started with searching the junkyard for seats. I had a set of front seats from a 2003 suburban but they were for the farm truck. I found a really nice set from a 2004 F150. Black and grey cloth, I prefer cloth over leather because you don't slide around and it warms up faster. Cool looking and in good shape. But there are major hurdles using these in a regular cab square body. I'll explain as I go. I found a console to match the style which wasn't easy because most of those trucks had the shifter in the console or had a split bench with fold down arm rest console. A friend had a good grey dash pad. So I had most of the pieces to get started. Pulled out the bench seat, dash pad, door panels, carpet, everything. And found that the water soaked passenger side had virtually rusted the floor away completely. So that needed to be addressed. |
5 Attachment(s)
BTW, these pics are oriented correctly on my phone so I can't tell how they will upload.
Carpet was in great shape. But I was changing colors. The floor pan change wasn't too difficult. The driver side just needed a cleaning and coat of paint. There were a couple little holes I filled. How about that rust protection?! |
5 Attachment(s)
Now that the rust was fixed it was time to make the seats fit. I was thinking it would be pretty easy but nope. They were too tall, narrower than expected and the seat back was THICK. They weren't power seats and I knew they would be positioned as far back as possible and always stay there. But I needed to get the seat height down significantly or they just weren't going to be usable. I almost resold them but instead I removed the adjustment tracks. That got almost 3" off. The back of the floor has an up angle so I notched it for the rear seat mounts. I tried to center the seat to the steering wheel and after I got it in I thought I had made a mistake but I remeasured and it was fine. The front mount had the seat bracket hole line up with one of the original mounts. The other side required a new bracket made to fit to the other front seat mount hole.
I couldn't find a pic of the bracket I made but it was pretty basic. Also I liked that the seat belts were incorporated in the seat. Especially since I broke bolts removing the original belts. The next challenge was the seat back, which was a little more upright than I like. My neighbor does upholstery work so I brought them to her and she cut out some of the padding at the top rear end restitched it. And also removed the headrest. That gave me a couple more degrees of recline. In the end I don't recommend these seats in a regular cab square. Just not enough room front to back. Even after all this work the steering wheel is too close for comfort. I swapped wheels with one from a 90s truck which is slightly smaller. And I have read about some people pushing the column forward for more room. I will likely try that yet this summer. |
5 Attachment(s)
The console mount wasn't bad. I made a bracket for one end. The other fit the floor alright. The rest of the interior work was just cleaning and painting. I used some dye for the plastic parts. The door panels were really sun damaged on top. I used them but if this was more than a plow truck I would have replaced them. I found problems with the heater controls so they are pretty much stuck on at the heater box. The fan wouldn't go to high speed. There was crap wiring to fix. The plow control was mounted to a bracket that was where the ash tray was. The dash speaker was blown and I bought a pair of small ones to replace it. Getting that out was one of the most difficult jobs on the whole interior swap. The rear of the cab separated from the floor on the driver side. I fixed that with panel adhesive. And a big mouse nest in the cab corner.
I pretty much sprayed every piece of the interior that was used except the steel dash and the seats. The door panels I did in 2 tone and repainted the chrome trim with chrome rattle can paint. I think they turned out great. The key is getting used plastic as clean as possible so the paint doesn't get fish eyes. Every crack, scratch and pore gets body oils and other oil based cleaners like armor all in them. It sucks. |
5 Attachment(s)
More pics...
I went with a charcoal carpet. Also got some decent floor mats to protect it. It's all coming together here. |
5 Attachment(s)
Carpet, seats, console, doors and dash were sorted out. Next was the stereo. Nothing fancy. I had an old 2 post clarion but the tuner adjust knobs didn't move right so it wasn't a good option. A friend had an old pioneer that still worked so I used that. The wiring was messed up of course but I got it sorted out. I found some factory cab corner speakers at the junkyard. I think I used a pair of 4" speakers in the dash and 4x10s that fit the cab corner brackets. I had to fab up a little stuff for the dash speakers but they fit and the dash pad fit over the top good.
It really needs more bass so I might add a powered sub at some point. I really don't use the radio when I'm plowing because I want to hear what is going on with the truck. But it works well when I want it. |
4 Attachment(s)
And the final pics...
Wow, good refurb! And quick too. You've had this truck what, like 15 minutes? Came out nice. I don't think you said what engine it has, or I missed it.
4 Attachment(s)
About the only other thing I did to spruce it up last fall was a tiny bit of body work. The dually fenders had some cracks and a hole to fix. A little bit of fiberglass and some rattle can paint. Oh and I scraped off the blue tape stripe. And this is what it looked like last week.
5 Attachment(s)
Winter is over and it's time to finally swap out the front axle. Last year I found a cab and chassis chassis for sale. I know that sounds odd. But I thought it was a regular dually chassis. I didn't notice the rear axle was narrower than normal. So my plan to swap both axles wasn't going to work. And the front axle needed a bunch of work that I didn't know about either. The front brakes were rusted to the rotors. The seller said that one of the stub shaft u joints was bad. He didn't know that the entire passenger side hub was full of rust.
Early winter I got the axle off the chassis and into the shed so I could work on it on warm days over winter. It took a long time to get the rotor off because after trying every method I could find I ended up cutting the hub in half so I could get to the lockout gear which also had to be cut off. Everything on the passenger side, including the stub axle had to be replaced. Luckily I found a 4x4 shop in Glencoe that had what I needed for a decent price. Sids 4x4 for anyone interested. He was very helpful. He said he's had to cut a few off over the years. |
3 Attachment(s)
I collected the parts I needed and finally had some time over the last month to start putting it back together. I had the rotors turned down. The lockouts I had were pretty crappy looking. One was a Spicer, one was something else. Both had severely corroded outers. They were functional but after all the work money I put into this I splurged and got some new mile marker hubs. Stainless steel and super easy to install. I cleaned everything up and splashed some paint on it.
Another pair of new tires and powder coated wheels. |
2 Attachment(s)
Another change I'm making is adding a leaf to the spring packs. I pulled a pair from the donor chassis. The weight of the plow only drops the front an inch but I will be widening the plow this summer. Unfortunately I wasn't able to finish the swap over the weekend. With the added height of the spring packs the u bolts were too short and I was only able to find 2 of the 3 on Sunday. I got the 3rd one made today at a suspension shop in Omaha. I'm waiting for the new shocks and steering stabilizer to get delivered. Should have it finished this week.
Interior looks awesome!
By the shifter looks like you may have an Np203. Very cool rig |
2 Attachment(s)
Back to work again this afternoon. All the U bolts are in and torqued. Sway bar reattached. Driveshaft on. Steering pitman arm attached. Passenger side brake hose replaced. Driver side almost. The F'ing hard line twisted right by the nut for the hose. So close to finishing. Oh well, Friday or Saturday it'll be done.
Neat 'ol truck! Glad it's worked out for ya.
