relay type and quality
Looking for some opinions on. is there a big quality difference in different brands of relays that are used on cooling fans and fuel pump. I just blew one on the ecm that was installed when I sent my harness out to get it re worked.(2 relays 4 fuses) Everyone I have sent out comes back with the standard type relay set up. Are people replacing these with better quality relays?
Your thoughts. |
Re: relay type and quality
One of my pet peeves is cheap relays. I use these.
https://www.racetronix.biz/p/relay-c...s-iso/rycs-001 |
would you change the socket also or just the relay?
I use the metri pack socket that comes with the relay.
The aftermarket harnesses I've bought used Hella. Never had a failure. I've used Painless fan kits with good success. What ever you use make sure they are rated for the max amp draw.
quick question. All my relays are 4 prong. Can I use 5 prong relays on four prong applications? Thanks
