What this bracket for ?
I have a 72 C10 step side. I think at one time it was a 3 or 4 speed. Getting ready to put in my new 350. I notice this bracket ?? For what ? Also another bracket or brackets that were cut off with torch.on both sides. I'm guessing two the brackets because they were mounted inside the frame top and bottom. I remove the cutoff brackets. Nothing on the glove box.
Re: What this bracket for ?
Can't quite tell in the photo but maybe for the z-bar?
Yeah that's the z-bar bracket. I've spent a lot of time staring at one of those lately.
What is a Z bar & what it do ?
It connects the steering column linkage to the transmission so you can put it in the correct gear on an automatic transmission.
thats one blurry pic
https://www.usa1industries.com/1963-...sembly-sb.html |
For others wondering about it here is where it would be mounted on the frame.... LockDoc |
It’s for the clutch bell crank from the pedal to the clutch fork
