Front Spring Hangers... Any Help?
So I broke a front leaf spring (custom alcan spring) When I pulled it off, I notice the front factory leaf mount is wallowed out a bit and wore down... Not sure if the PO had wrong sized bolt??? But now that I am into the project I would not mind upgrading the hangers.
I am aware of the B52 set up, I dont have the factory bumper but dont do not want to spend $550 to just fix the front hanger... Any other options? Of course this is for my my K5... |
Re: Front Spring Hangers... Any Help?
Moved to 4x4…
I would bet Diy 4x4 would sell just the front hangers if you are interested. Off road design has some but only for square bodies. Posting a wtb in the parts section is another route if you do not want to repair yours.
http://67-72chevytrucks.com/vboard/s...=662879&page=5
Post 122 is how I fixed the same problem on mine. You likely don’t NEED hangers, but to a point I can understand wanting to upgrade. What are your overall plans for your truck if you don’t mind me asking? |
Do you recall what size the washer was for repair? I swear my front bolts are 9/16 but the spring builder swears they should be 5/8 and 9/16 is an odd bolt size etc. |
What about just replacing with a factory hanger. 9/16 is not an odd size for these trucks or any chevy truck for that matter
Mine are 9/16 bolts for sure. I just picked up the thickest 9/16th washer I could find.
I just have the drivers side 45 shipped
I have a B52 kit that I am not going to use if that helps
Gene |
