Radiator Shroud for 6 cylinder
WTB. Looking for a plastic Radiator shroud for a 6 cylinder 292. Thank you.
Re: Radiator Shroud for 6 cylinder
Hello there. I have several fan shrouds but not sure for what radiator and engine set up. Can you help me identify what you need for your 6 cylinder.
Thank you. Dan |
Hi Dan.
I wish I could. Mine didn't have one on it and I don't know what it looks like. Thank you |
I'm pretty sure the six cylinders never had a fan shroud, just a finger guard. That's all my 250 had. My 292 never gets over 180 degrees anyway.
They made them as a "Heavy Duty Radiator Fan Shroud". There was one listed on this site before. Thanks.
My 69 inline 292 came with the RPO option "heavy duty radiator" listed but had no fan shroud, just the finger gaurd. Good luck with the search. If found, please post a picture.
Can you tell if there are factory numbers on it anywhere? How many blades are on your fan? Thank you.
I just ordered a new 3 row brass/copper radiator along with a fan shroud for a non a/c sbc for my inline 6 last week from LMC. Should have it by thursday this week and i will keep you informed if it works out.
I ended up buying a fan shroud from LMC for a sbc and cut it out to fit. I’m still wanting an original one for it.
I put in a three row factory radiator as well. I had to cut part of the side of the fan shroud out and the bottom so it would fit. My truck is a 1 ton chassis.
