Heater Delete Plate For Dashboard ?
A fellow member that once produced the delete pieces for under the hood was also going to make one for the dashboard, did he ever offer them ? I emailed him but didn’t hear back ?
Re: Heater Delete Plate For Dashboard ?
Went down the rabbit hole on this...there were factory delete plates..but rare indeed. Here's one that appears to be rather crude: https://www.a2metalfab.com/products/...l-delete-panel Ebay has heater control rebuild kits that you could maybe use to build your own: https://www.ebay.com/itm/15407149443...Bk9SR9yhx8a0Yw There's one factory radio delete panel on eBay, but it's gonna be smaller than the heater control panel. Hth, -klb |
Thanks so much for the link !
2 Attachment(s)
On an early truck, I used the opening from the heater controls and mounted a DIN style radio/stereo unit. I then used a radio delete and mounted my 3 round knobs for the Vintage air controls. I can't find the pictures on this computer. I do remember that I welded two metal tabs on each side of the opening as the heater is slightly wider than a DIN hole.
Found a couple pictures. |
3 Attachment(s)
I am using a standard radio delete plate in that location. Moving controls for custom AC/Heater install into the panel below I made from an extra glove box. Panel will have ac/heater controls, two air vents, and LED rocker switches for 4x4 lighting.
Here is a picture of the start of the panel. |
So, what does the bigfoot button do???
2 Attachment(s)
I used a 1/2” piece of aluminum to make a filler panel.
I then used it inside of the stock heater control panel, and then decided to put the Dakota Digital control panel in it, along with my electric fuel, and fan bypass switches. |
X2 on the radio delete plate as a heater delete plate
Check out the factory run/sag in the paint on the ashtray |
You guys sure have the touch when it comes to fabrication ! Congratulations to you all !
You’re looking for the proverbial “Unicorn, with a Golden Horn,, and Mermaid on its back”.
They exist, but I’d venture to say that the Heater Control delete Plate is the rarest of rare options/parts. To my knowledge, they only went in a few fleet trucks, destined for tropical markets. |
I’m sure they can be found on Amazon as well. |
:chevy: |
https://www.amazon.com/gp/aw/d/B07HG...b_b_asin_title |
