My '74 can of worms (Green Machine)
Like always these projects take a life of their own....
I've done so much to this thing and now im finally reassembling it (my shop is moving to a better area, so i need to get this rolling. I por15 the entire frame with a little green sparkle added for something different, came out better than i was thinking. 383, TCI 700r4, captn fab rear brake hardware with willwood components and a rebuilt hydroboost pump found from a K10. Rearend is a 12bolt with Yukon Suspension is Ridetech all the way around. Kept the leafs in the back, dont wanna deal with 4link mods. Waiting for Summit to put Edelbrock ProFlo4 back on sale so i can pull the BPE Holley fuel crap off. Have a Mutha Thumper roller cam that'll be going in here pretty quick. Anyway, these are my most recent pics... ** see below for pix |
Re: My '74 can of worms.
You okay? It's like you disappeared while posting.
5 Attachment(s)
Lol Some weird matrix sht. |
I dint know why my pics post sideways.
Nice work, that green is awesome, what paint is it?
I think the sideways pics has something to do with the orientation of the cellphone when you take the pics. |
3 Attachment(s)
The green on the truck is called Galatic Green (i think) and the parts are all powdercoat. Its been a while, i forget the name. But, its better looking than the paint. |
3 Attachment(s)
This is what it looked like when i bought it....
It's amazing! Can't wait to see the completed truck. Good luck, Rg
2 Attachment(s)
Can anyone point me to where i can get these lower control arm saddles? Cant find them anywhere!
Look at these part numbers 3907838 3907837 One is left and one is right. Says they fit suburbans from 1984-1991, but I think the suburban cross shafts are the same as the other squarebodies. You'd have to research that.
Not sure if they are correct but they sure look like them. What's wrong with yours? |
Whoever had dreams for this truck had already pulled these off and one is taco'd pretty good. They had weird mismatched bolts as the centering pins, a somehow did some strange work on the crossmenber where they mount. Glad i caught all this before i started my frontend reassembling... Thanks again! |
Ya, i did browse and "search" im gonna use an allen sockey head... I was debating doing a caster mod, but id have to dissasemble the lowers again... did you do that? Is it that big of a deal? |
I've never done it but supposedly it is worth the effort to get rid of a bunch of shims.
Gotcha Im curious if aftermarket lowers make the adjustment 🤔 I 'think' i have DJM lowers, ill have to look a little deeper. |
5 Attachment(s)
Just some updates...
Got the rear 'pretty much' togeteher. Got the rearend hung, new front hangers and my brake bracketry all did... We stabbed the motor tonight and i did the caster mod on my front lowers. Hopefully get my front end and cam in tomorrow night. |
3 Attachment(s)
Nice work, did you get a cross shaft bracket for the lower control arms?
Thank you I did not buy any. We were able to massage the 2 on the vice. Paint and all good! Whoever did the work before me didnt even have the alignment holes on the cross shaft "locked" in anyway... a modification was needed regardless to get the control arms to set in the pocket.... |
3 Attachment(s)
Motor in.
If you zoom in on the transmission crossmember frame mount you can see the frame fortification i did... Hopefully he will be on the ground next week ! |
:metal::metal::metal:
:metal:
3 Attachment(s)
Starting to look like a squarebody.
5 Attachment(s)
My bed is almost done, check out this work!
Rest of the project is moving along at a snails pace, but why would these be quick... ? |
