sm465 conversion
Looking to put a sm465/np205 in place of my 400/205. my cab is a 64gmc sitting on a 84 k10.Plan on getting capt fab parts for the cab components. I have a newer 383 so I'll need a weighted flywheel. I know AA has kits for the clutch slave But I also have a 65 c60 and a 66 c20 with hyd clutch. Can I use the slave components off of one of them?
Re: sm465 conversion
nevermind. The 66 is mechanical and the 65 has nothing that I can use
Double check that your 383 isn't internally balanced. My 400 scat crank is.
As far as your swap goes. Get the frame bracket and z bar for a square body and pedal assembly for a 60s truck. Then you will only need to fab the linkage between the pedal and z bar. The 60s hydraulics would probably run the hydraulics on a squarebody hydraulic clutch but those bellhousings are unique. The lines and slave cylinder for an 86 1 ton should get you a cast cylinder. |
Classic parts used to sell the z bars. Frame side is nothing more than a chunk of angle.
