Pass. Upper shock bolt hole
Hi, I have 1986 C10 swb. I am trying to find the dims. to locate the pass. side upper shock bolt hole location (in frame)? I need to check/redrill the shock hole location from a frame repair. I am not sure if there is a factory assy. manual for it (similar to the 67-72 trucks)? any info. would be appreciated :metal:
thanks!:ito: |
Re: Pass. Upper shock bolt hole
I looked at a bunch of frame drawings, none show shock location
Could you not measure drivers side and mirror it to pass side? |
Should be a dimple in the frame, I'd find the center of it and drill and watch out for the brake line behind it
Link to build thread?
Here it is KW
http://67-72chevytrucks.com/vboard/s...=794677&page=5 I thought you were referring to the front.. If the shock is installed on drivers side, measure the installed shock length from bolt center to bolt center.. Then measure how far from top or bottom of frame rail to frameside stud.. Transfer this measurement to pass frame rail in the general area of your patch Then measure the pass side from axle end shock mount to the frame repair area using the installed shock measurement You should be able to visualize where the hole needs to be where all these lines intersect.. It wont matter if your measurement is off a little |
2 Attachment(s)
Going by this pic,...pic1
I'm gonna say probably in this area...pic2 |
mongo, thanks for the link info & THANK YOU for the replies. I will try your suggestions this weekend. your 1st picks helps. I believe that I might have drilled to "low" making the shock sit "higher" on the pass side... not sure though. hopefully you didn't laugh too much while looking thru my build. I need to add some things as the truck is emissioned & driving now.
