Can I safely remove this part?
I have lowered my truck, and the exhaust pipes up front, now hang lower to the ground. They need to be raised up a few inches.
The cross member in the photo blocks any upward raising of the pipes. Can it be removed?? It is bolted in, the rivets have bee removed, so I assume it was removed at some time. It is not supporting anything, as I have a tubular transmission mount further back to accomodate my 700r4 I seem to remember that this was some type of bell housing support. |
Re: Can I safely remove this part?
Yes you can remove it. That supports the back of the engine when you have the factory 3 speed trans in as there is no cross member for them.
