Re: Building a Custom GMC Dash Bezel from the ground up :).
I don't think you'll have any visibility issues with your gauges or your stuff at the bottom. It will be even easier if you have a tilt column, but I eliminated mine as it just wasn't really needed any longer.
I never had a plastic original bezel to work with. Mine was always metal, and as a result it always chipped the paint from the dash when being removed. That's why I cut the rim off mine and screwed it to the dash opening. This way, I could add and remove the face plate without scraping anything up.
