Old 02-01-2024, 03:29 AM   #276
LT7A
Re: My winter project
Originally Posted by LT7A View Post
Wow, that pile of shrapnel really tells the story. How did it drive? It sure looks good. Thanks for telling about the build process and posting pictures. I actually can relate a lot more to a build like this than the custom ones.
It's been awhile since I've been back to check out this thread. You've made a lot of progress. I was thinking, this guy responds to every comment, why not mine? I went back and looked at it and maybe it wasn't clear. The shrapnel I referred to was this picture. And back aways you had mentioned you had been driving it but you never talked about what it was like to drive. So that was the nature of the question about that.
Old 02-01-2024, 09:36 PM   #277
7D2N
7D2N's Avatar
Thanks for checking back in. Yes, there have been a few piles of shrapnel while doing the rebuild. I have driven the truck but on small test drives checking how it runs, stops and looking for leaks, and damn the transmission pan has a drip.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 02-29-2024, 08:47 PM   #278
7D2N
7D2N's Avatar
Just a little body work getting done. I'm starting to understand the cost of my body/paint quotes.
Old 02-29-2024, 08:55 PM   #279
7D2N
7D2N's Avatar
Working on the doors repairing the skins and the screw holes.
Old 03-20-2024, 07:25 PM   #280
7D2N
7D2N's Avatar
Getting close with the bodywork and the primer is on repairs. I put the oil fill tube on and that was more fun than bodywork.
Old 03-21-2024, 01:27 AM   #281
Spf79
Spf79's Avatar
Looks great!!!
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 04-02-2024, 08:28 PM   #282
7D2N
7D2N's Avatar
Next time I take it all apart it will be for final primer and paint.
Old 04-20-2024, 11:08 AM   #283
LT7A
Good progress on the body work. Can you say what you used to paint the air cleaner? That is a very nice sheen. A little flatter than most.
Old 04-22-2024, 10:15 AM   #284
7D2N
7D2N's Avatar
Thank you. The paint is (low-gloss) black in the high heat type I have used it on other parts on the blazer.
I did get the side glass in the top.
Old 04-22-2024, 10:34 AM   #285
7D2N
7D2N's Avatar
Anyone know how the 3 seals joins together in the door area?
Old 05-01-2024, 08:53 PM   #286
7D2N
7D2N's Avatar
I have a beat-up lower door trim and some leftover chrome paint. I know it's not show quality but this will work until I can find a decent original.
Old 05-03-2024, 09:56 AM   #287
raggedjim
raggedjim's Avatar
Great work on the bodywork. It's definitely my least favorite thing to do.
Trim is looking good!
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 05-03-2024, 09:06 PM   #288
7D2N
7D2N's Avatar
Good luck, Rg
Thanks Rg. First time body work guy and since I'ts not going to be perfect it will be good enough.
Old 05-05-2024, 03:34 PM   #289
7D2N
7D2N's Avatar
I fought the hatch glass because it would not set right. So it turned out the raptor liner coat was a little thick, trimmed and sanded a bit and it right went in.
Old 05-09-2024, 07:12 PM   #290
7D2N
7D2N's Avatar
Playing with another piece of beat up trim.
