Old 04-03-2023, 08:10 PM   #26
lawrenq
Re: 1970 C10 project
Made some more progress with the truck. I mocked up some porterbuilt hinges and welded in my Altman door latches.
lawrenq is offline   Reply With Quote
Old 04-04-2023, 12:42 PM   #27
68isgreat
Awesome. I see you're going with a 68 grille instead of the 70? Also, when you smooth out the firewall like that, where does the wire junction box go on the firewall? Great job so far!
68isgreat is offline   Reply With Quote
Old 04-11-2023, 06:31 AM   #28
lawrenq
I'm planning on bringing it out at the side so that runs in the fender so ot won't be visible when everything's back together.
Old 04-11-2023, 06:36 AM   #29
lawrenq
I rebuilt my vent windows, I had the frames powdercoated satin black. The glass is from auto city classic. I went with a later style locking vent knob. I also followed the thread here about dyi power windows and converted my passenger side to power. They work great, better than the nu relics in my chevelle.
Old 04-11-2023, 11:44 AM   #30
Stickman
Stickman's Avatar
Originally Posted by lawrenq View Post
Made some progress on the truck. Finished the body work on the interior of the cab and tried out a color that I was thinking about. I also found a pair of new bed sides and a new woodbed kit for a longed that I just have to cut down.
As I said before very nice work. I noticed you deleted the wire channel like Grumpy and few other have done on here. What was your procedure in doing so, did you cut off the lip and weld a strip over over the top or otherwise? Looks awesome and I like the color.
Stickman is offline   Reply With Quote
Old 04-11-2023, 11:51 AM   #31
lawrenq
Thanks, I bought the firewall kit from slosh tubz and it came with the filler piece that goes over the wire channel. I didn't have to cut anything I just layer the filler piece over the top of that channel and welded it up.
Old 02-26-2024, 06:17 PM   #32
lawrenq
Getting back to working on this truck I have been slacking on this project for the last year. I have most of the body gaps where I want them but I think my hood may be too long. It sticks out slightly pass the fenders. I've seen this on other trucks that weren't original. What's the best way to fix this?
1st two pictures are not my truck, but my hood looks similar.
Old 02-29-2024, 04:42 PM   #33
68Gold/white
I sold two 67/68 O. E. hoods to a friend in Texas, because his aftermarket hood had similar problems.....
68Gold/white is online now   Reply With Quote
Old 02-29-2024, 06:34 PM   #34
lawrenq
Exclamation Re: 1970 C10 project
I wish I could find some nice originals but they're hard to find here on the east coast.
Old 02-29-2024, 06:39 PM   #35
lawrenq
Here are some more pictures of the hood and fenders. I think it may work out better if I cut the fenders to meet the hood.
Old 03-06-2024, 10:20 PM   #36
lawrenq
I found a good deal on a set of Wilwood brakes on Amazon for my truck. I was going to make some brackets and run late model Chevy truck front calipers but buying the kit saved along of time and frustration.
Old 04-23-2024, 09:36 PM   #37
lawrenq
I made some progress on the body and decided to put some paint on it for time being. This was my 1st time painting and I'm not too pleased with the results. I still have some cutting and buffing to do but this will have to do until i move to a bigger place. The color is Tamco's Rock it Red.
Old 04-23-2024, 09:45 PM   #38
lawrenq
Originally I had planned on a turbo ls build, but i found a deal on a 2018 LT1/8 speed pullout from a Camaro SS. Right now the plan is to tune out the dod and later on I might change out the cam. I also plan on using the factory pwm fan and fuel pump.
Old 04-24-2024, 09:31 AM   #39
raggedjim
raggedjim's Avatar
From what I can see the paint looks great. Unless the corner of the hood has more pearl than the other areas? Not sure if the paint is a pearl or not.
You've done a great job on this truck. What did you ever do about the hood being too long?
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-24-2024, 09:07 PM   #40
lawrenq
Rg
Thanks and for the hood I sliced it and re welded the hood back.
Old 05-11-2024, 09:00 PM   #41
lawrenq
I made some more progress and have the engine sitting in the truck. Since I'm using the Holley LS frame mounts, they work with the Gen V engines by changing the clamshells that mount on the engine. I swapped out the oil pan with a Holley knock-off pan. All of the accessories from the Camaro fit, but I swapped out the Camaro's alternator with one from an LS truck since the plugs are on the back and not on the side.
