05-26-2024, 02:22 AM | #1 |
Tool Stowage Box Door Repair Help
Hey guys, I’m repairing this tool stowage box door and looking for some input/advice. It has cancer rust in the corners, I media blasted the affected areas to get a better idea of what I’m working with. Also had to repair the hinge for the latch/handle. I decided to split the door in efforts to keep the hemmed edge around the perimeter. After splitting in two pieces, it appears the entire bottom of the door should be replaced due to bad corrosion internally (not much original metal left to make me feel comfortable buttoning up only to have it rust out again in a couple years). I would like to retain the hemmed edge, what is my best option to repair this door?
1965 c/10 swb 1969 c/10 lwb |
05-26-2024, 04:05 PM | #2 |
SWB 4x4 Collector
Re: Tool Stowage Box Door Repair Help
What about making the front of the door whole again and then cut the rear off and reuse the lip by welding on the edge, then grinding down. Could also use coat hangers or thick welding wire (like when welding up door gaps) on the edge and welding a new cut out lip for the back.
Just a thought, that would keep the backside lip. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-26-2024, 05:32 PM | #3 |
Using Trevor's advice if Classic Industries ever get this panel in the link below,
You could use it and weld the indention in a new panel. Also If you could find a doner bedside you could do that also. Link: https://www.classicindustries.com/product/t70226.html
