Old 04-19-2005, 10:53 PM   #1
Bryan68custom
front end noise
I have a 99 z-71 with a little over 100,000 miles that makes a rattling noise from the front end when driving between 20 and 40 mph. I have had it up on my rack and cannot find anything loose or for that matter any extra play in it what so ever. I thought maybe someone has had similar problems so I dont have to change parts till I find whats wrong.
Bryan
2004 Extended cab LS silverado
2001 Buick Lesabre
1968 Chevy Custom 10 LWB Anniversery model
2008 crew cab lt (rolling on dubs)
"The nice part about living in a small town is when you don't know what you're doing, someone else always does"
Bryan68custom is offline   Reply With Quote
Old 04-22-2005, 07:34 PM   #2
Josh
He's got mean nasty FANGS!
Josh's Avatar
Check the usual, ball joint, etc. make sure the crossmember botl are tight, also look at the bushings the the torsion bars mount through, on the frame and A arm, i've seen them wear out on the frame and sound like a front end noise. If you can, get or borrow a set of chassis ears and start checking everything to try and pinpoint it.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
