Old 09-11-2020, 01:40 AM   #1
LindsayB71
67 C10 6 lug to 5 lug drum brake rears - Whats compatible ?
Hi from Australia.....I have a 1967 Chevy C10 and I want to convert the 12 bolt 6 lug rear end to a 5 lug rear end and keep it drum brake. Is there any other compatible year i can use for the rear drums ? Current drums are 11" x 2"
LindsayB71 is offline   Reply With Quote
Old 09-11-2020, 02:41 AM   #2
gmc684x4
Re: 67 C10 6 lug to 5 lug drum brake rears - Whats compatible ?
For the 60 to 69 12 bolt diff you can buy new axles
Moser makes a set so do several others places some places to order are summit racing gmc pauls ece cpp lmc to name a few
Other way is look for a wider 70 diff or the 71 72 diff which is already 5 bolt
Or get a 5 bolt out of a 73 81 square body
Ece sells a kit that you can retrofit the newer axle in
If your axles are in good shape where the bearings and seals are riding on the axle you could have them welded up and redrilled by a machine shop
My 1/2 ton project i am switching up to 11x 2 3/4 mainly from the fact i have a good set with new brakes
What does your truck look like ?
I never seen any c10s when i was down under years back
Other thing i have thought about was use 6 bolt front rotors and use 17 or 18s of newer chevy trucks
gmc684x4 is offline   Reply With Quote
