Old 12-14-2017, 08:33 PM   #1
Old Radio Tech
Spring hanger/shackle pins
1965 K10 Suburban with leaf springs front and rear. Replacing the hanger/shackle pins and bushings. Working on the rear. Got the front hanger pins out by hammering out from the inside (slide hammer did not work). I can't get at the lower rear shackle pins to hammer out from the inside without dropping the gas tank first. Before I start beating on them from the outside in wanted to get some feedback from the forum. Can the pins be removed from the outside in or will they get tighter with each blow?
Old Radio Tech is offline   Reply With Quote
Old 12-20-2017, 08:17 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Spring hanger/shackle pins
Moving this to the suspension area, hopefully someone will have an answer
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-15-2018, 11:02 PM   #3
wahl4m
ive heated up the bolt heads & use a big impact wrench & try to unscrew them ?? if your bushings get screwed up -go to a spring shop & replace bushing & new grd 8 bolts -should be available at local hardware -i use a good grade_ self locking -flange nut
wahl4m is offline   Reply With Quote
Old 01-16-2018, 11:25 AM   #4
Old Radio Tech
I drilled out the grease fitting and tapped to fit a 3/8 grade 8 bolt connected to a slide hammer. still no go. Dropped the tank and came at them from the inside with a large punch. They cooperated. Job done now.
