05-27-2024, 10:14 PM | #1 |
3/4 ton rear diff help
Ok so I picked up another done truck and pulled the rear end out only to find driver side spi s good but passenger side won't budge. Pulled the cover a d the gears spin around the locked up gear . No glitter in the oil no chipped teeth that I see. Ok so I think maybe the brakes are seized.. now I'm trying pull the drum of and man it's not moving out.. it'll wiggle a little. That's it.
Any ideas why the passenger side would not move at all? And any counters on removing this drum. I'm beating the hell out of it after removing the 2 screws 10 bolt 3/4 ton rear 8 lug
1967custom |
05-27-2024, 10:23 PM | #2 |
Re: 3/4 ton rear diff help
You need to remove the axle first then the cage nut . Drum will then come off with the hub . Much easier than trying to separate the drum hub assembly
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 05-27-2024 at 10:45 PM. |
05-27-2024, 10:28 PM | #3 |
Who Changed This?
Maybe try using some tools and back the adjuster off enough to allow the drum to rotate. I've seen rivets into the drum where the friction material was completely gone, believe it or not. Took a lot more backing off of the adjuster to get the drum off.
05-28-2024, 05:22 PM | #4 |
At the body shop.
My 68 had the adjuster spring break. The spun themselves until the adjuster separated.
Had to cut drum open to disassemble. And was outboard drum
" That didnt make it any newer " " Dont antique the equipment " |
05-28-2024, 09:45 PM | #5 |
Born Psycho
looking at your second picture that gear oil looks like it has water in it and it appears to have rust on the ring gear. i know that has nothing to do with your question but i thought i'd point it out.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-28-2024, 11:34 PM | #6 |
I appreciate all the help fellas. I'll try spinning the adjuster back manually first if that doesn't do it I'll remove the hub.. never do e a 3/4 ton. I'll be taking lots of pics.
Side note... when I removed the brake cables the seized side was tight to where I had to cut the cable at the coupler to remove it. Driver side separated no problem.
1967custom |
05-29-2024, 08:50 PM | #7 |
Proprietor of Dale's Corner
It looks like a dana 60 open diff. Get the axles out and use shop manual or u tube university to help you through.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-29-2024, 10:21 PM | #8 |
72c20custom camper. Any idea what size this nut is so I can go buy the socket?
1967custom |
05-29-2024, 10:49 PM | #9 |
They make stamped steel sockets for this size nut.
Just measure it across the flats for the size. |
05-29-2024, 10:58 PM | #10 |
At the body shop.
Hammer and a chisel will work as well.
05-29-2024, 11:59 PM | #11 |
Who Changed This?
To get it apart, just push the locking tang away from the nut, and use #460 Channel Locks or similar to remove the outer nut. Then slide the locking washer off and unscrew the inner nut. There's a spec for end play in the service manual, but I've installed many of these over the years by feel, without any failures.
05-30-2024, 08:29 AM | #12 |
I just used a water pump pliers like others said a punch and hammer work well also
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
05-30-2024, 08:57 AM | #13 |
I have the welded socket. All the ways mentioned will work fine.
05-30-2024, 06:20 PM | #14 |
Imma go give it a shot now
1967custom |
05-30-2024, 07:07 PM | #15 |
All about them K’s
Don’t forget to knock the lock tab back so the nut will spin.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
05-30-2024, 07:56 PM | #16 |
It looks scary, but it's easier than it looks.
06-01-2024, 09:17 PM | #17 | |
Active Member
When you get to reassembly, please, for the love of god, use the nut and the correct preload sequence and torque specs from the manual. I had my Dana 60 rebuilt last year by a local specialist and one of the axles seized less than 7 miles from the shop on my way home, destroying the entire rear end. They did not lubricate bearings correctly and did not follow the torque specs.
1971 Pontiac Firebird 1971 GMC C2500 |
06-01-2024, 09:26 PM | #18 |
Active Member
Not sure if you are going through the whole assembly but I'll just throw out some part numbers while I'm here:
Axle Flange Gaskets; p/n QU30051 from TorqueKing. If you're not into RTV, they seem to be the only place on the planet that has them Drum brake spring kit; Dorman HW7027 should be correct. There's a bunch of others on RockAuto that are not correct for the Dana
06-01-2024, 09:55 PM | #19 | |
06-01-2024, 09:58 PM | #20 | |
06-01-2024, 10:20 PM | #21 |
Who Changed This?
I'd bet money on that too. You'd think that an axle shop would know that.
06-01-2024, 11:42 PM | #22 |
Active Member
Correct. The first time around he said something like, "oh yeah, you just squirt some diff fluid into the hub and the rest of the lubrication will come down from the center section". He also mentioned using a hammer/chisel in lieu of proper socket for the nut. I thought it was crazy, but hey, he's has a shop not me. His method may work for a newer vehicle, but it seems like the stock Dana 60 cover drain plug for our trucks is not high enough to permit fluid to travel down the axle tubes on initial fill. You'd have to do the tilt method and refill.
After it seized I dug into the manual more and found the blurb at the beginning that specifically says when you replace bearings, "repack with lubricant". I mentioned using the socket too because the original reason I ended up having my first Dana rebuilt was due to an axle leak. I thought it was another seal failure, but it was actually the hub working itself off the spindle due to the nuts spinning freely, because the axle lock-plate tab broke off and the index pin sheared. The year before I had an axle seal replaced by a different local shop, and based on the next coincidence and the marks on the nut, I have a feeling that was the seal they replaced and that they too used the "torque-to-bang" method, instead of a wrench. They also reassembled my drums incorrectly, so that was cool. Anyways.... use the socket and a torque wrench.
06-05-2024, 04:57 PM | #23 |
Man it has turned I to a job. The doner rear end shown in the pics ha sa seized brake cylinder Der that I cannot break amd I'm having to literally pound the drum off so I cannot see any further damage. I got the axle out just fine though. Now I have to put the do er axle in my truck. Any one know the specs I need for the bearing nut. ?
1967custom |
06-05-2024, 08:12 PM | #24 |
Who Changed This?
There is a spec for end play in the overhaul manual. You have that, right? If not, get it here-
https://67-72chevytrucks.com/vboard/...ghlight=hatzie Get the service manual while you're there.
06-06-2024, 09:11 PM | #25 |
No np overhaulamial. I used to have one but sold it on here years ago!. Thanks for the link.
1967custom |
