Vent solenoid location
2006 GMC Sierra 1500. Looking for the location of the vent solenoid. The place where I thought it would be has nothing that looks like it. Also I might not have the right part as it listed 2 different part numbers. So I'm not sure which one is there. Anybody run into this before?
Thanks |
#2 | |
Moderator
![]() Join Date: Oct 2008
Re: Vent solenoid location
It's on the rear of the fuel tank on my 2005 2500HD. The Vent filter should be along the LH side of the transmission if the TSB has been performed.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
laying low
![]() Join Date: Mar 2001
Evap vent looks something like this on my 06 GMC.
Yea I have the part and have replaced many of them. Just can't find the damn thing. I think I have to do some more digging. But thanks for the tips.
Some are at the rear of the fuel tank. Some are mounted on the crossmember near where the filler hose meets the tank.
Edit, here's some pics: |
#6 | |
Once I locate it the questions is...drop the tank or pull the bed?? |
Moderator
Dropping the tank is a colossal pain the the gluteus maximus. Not to mention the fact that dropping the tank disturbs a lot of stuff that's far better not disturbed.
Pull the bed. DO NOT USE an IMPACT GUN!!! It'll break the sheet metal cages around the captive nuts. Put Never Sieze on the bolts and inside the threads on the captive nuts when you re-install the bed.
I have changed them without doing either. I stick my hand up behind the cab and then go on top of the frame rail. It’s held in with a tension clip.
Moderator
I actually recently replaced the tank pressure sensor without pulling the bed or tank.
Reached between the bed and the frame and did it by blind feel. Thankfully there wasn't much dirt but I loosened what dirt there was with my fingers and blew it out with a backpack leaf blower. Nasty job but easier than pulling the bed or the tank. I was told by a mechanic that wasn't possible... after I'd already done it. Here's your sign. ![]() ![]()
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-09-2018 at 11:11 AM. |
I changed my 06 silverado 4wd quite a while back . I did not remember it being a problem . Seems like it took like maybe a hour .
What I do remember is the kit they wanted me to put was expensive . I did not use the kit and found out there was another valve that fit perfect with no problem and was less than 1/4 of the price . The kit comes with a hose and filter and they want you to run it to the front of the trans . I can change it several times if needed , But it has been fine for years . Just don't over fill the tank . When the nozzle clicks stop . If you give it more above that it will over fill and run into the solenoid and damage it . I was bad to do that . Just a little piece of info if anyone was interested . |
#11 | |
![]() Join Date: Dec 2001
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
#12 | |
So took another look at it to find this piece and I cannot locate this to save my life. Looked on top of tank with mirror and nothing. Looked all around and can't find it. Although I did find my shock mount broken in rear!!
I would think your 06 gmc would be the same as my 06 silverado . Look about center of the truck and center of the gas tank . You will see a square looking box which is a charcoal filter . There will be a hard plastic line coming off the rear of it . This line goes to the solenoid to the rear top of the tank . It is a quick release . Look at the second picture above . You can see the square looking box . Follow that tube back to it .
#15 |
laying low
The failure on mine was the filter itself filled up with dirt. I work in a dirt/gravel site so dust is terrible. I found the filter was full of it.
#16 |
Moderator
You can just clean the crud otta that filter. The open cell foam is basically the same stuff as a Wall AC air filter.
#17 |
Mine was on the front and to the inside of the fuel tank. Manual trans trucks use a different hose assembly. Usually you can pop the cover off and clean the filter.
If you replace it, just cut the rigid plastic tube it connects to and use a piece of hose to splice the new one onto the plastic tube..
2006 Sierra RCSB V6 5 Speed RWD. |
