![]() Join Date: Apr 2006
67-72 Sway Bar
So I was searching for a 73 Up front sway bar to convert my 72 and saw the below link.
Has anyone installed these? They are a little pricey but I'm thinking of getting them. https://www.sdtrucksprings.com/sway-...k/pickup-63-87 Instructions I found for the rear: https://static.summitracing.com/glob...s/hel-7413.pdf Cant find any yet for the front.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
Re: 67-72 Sway Bar
I have Addco bars on the front and rear of my Suburban.
They work fine but I had to modify the mounting mostly because of my 2" lift
Re: 67-72 Sway Bar
Looks like Hellwig discontinued theirs. Any idea the part numbers for the Addco kits? Do you have pictures of the install? I have a 3” lift on my k5.
Re: 67-72 Sway Bar
Someone rigged a later sway bar up on my '72 K2500 using a crossmember made from 6" c-channel. I removed it when I lifted it 4". I have used the sway bar spacers on other trucks I've lifted (73-87s), but I chose to remove it on this truck. I see very little, if any, benefit from sway bars on these solid axle leaf spring trucks. They already have a "firm" suspension that handles flat as a table top. I get a kick out of having a sporty car come bearing down on me as I'm hitting and exit, only to leave them way behind around the ramp. I feel they are unnecessary clutter. I guess if it comes with one I keep it and if it doesn't I leave it that way. I have owned an awful lot of GM solid axle 4wds, stock to lifted in various ways. I honestly see no real difference in handling between with or without.
Re: 67-72 Sway Bar
I’ve read a few people saying the same thing. I’ve wondered if it was worth the hassle. I haven’t finished the work yet to get it roadworthy from my LS swap and lift. I may just do some driving to see what I think before dropping the money on this option.
Kirk 72 Blazer CST 4wd highlander 66 Nova Last edited by Blazerowner; 07-04-2019 at 11:14 AM. |
Re: 67-72 Sway Bar
That has been my experience. I see sway bars as very effective for independent suspension. I feel no body roll in the four corner leaf/solid axle trucks. They handle flat as a Ferrari IMO, just higher center of gravity
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: 67-72 Sway Bar
I found on my 4" lifted 89 Burban that if I was going to do some serious articulation I needed to disconnect the sway bar to keep all four tires on the ground. I eventually just removed it altogether and didn't even notice a difference.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: 67-72 Sway Bar
Thanks for the info guys. I think I will just hold off on this and see how it drives. I bought new springs from ORD so I’m hoping for a little smoother ride on the street. The truck is a road and show truck for me so it will likely never see the dirt. I just have too much time and money into it. That’s what my other toy is for.
Re: 67-72 Sway Bar
aftermarket lift kit springs on these older solid axle trucks are more firm and tend to not need the sway bar anymore .
so unless you have stock soft or custom soft aftermarket springs i would not bother my self with the sway bar . i have run my few 73-87 k30's and a k10 with lift kit springs and no bar and 1 even had a snow plow setup that was almost 800-850 lbs extra and no real difference .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
![]() Join Date: Jan 2002
Re: 67-72 Sway Bar
I added a front sway bar on the front of my K10 adapted from a square body. I used the riveted factory square body mounts on my 71 from the frame of the donor truck. I flipped them from side to side and they fit amazingly well. The truck has a 2.5 inch lift with 1 inch zero rate "spring".
I feel the truck handles better but agree I wouldn't use them on a truck that is taken off road frequently as they limit articulation.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
Re: 67-72 Sway Bar
Are those the special order ORD springs that take weeks to make? How much of a difference did you notice? Worth it? Front and Rear?
Re: 67-72 Sway Bar
When I added my swaybar from a 73 up I just welded in a set of mounts and it fit in and worked fine. My truck has 4 inch lift with very stiff springs and the swaybar made a huge differance if you are pushing it hard through the curves. I don't know how you guys don't see a differance. I do not purposely go off reading anymore but the truck is in 4x4 every time I go up the driveway and when I am working in the yard doing winch work or firewood since I live on a mountain. Articulation is just fine. The only issue I have is when the wheel is cut all the way on a hill with wet clay it will sometimes plow forward instead of turning. Then again the backhoe and tractor do the same thing in those locations. Next time I do the hubs I am sliding a lunch box locker in the front. Just my 2 cents.
