![]() Join Date: Nov 2014
The Right Stuff 71-72 Disc brake line kit help
Just got a part # TKT7204 brake line kit and I noticed the tags have letters on them. Anyone made a list of where each line goes?
Amazes me that there isn’t a simple list of them with location descriptions or a diagram. Any help would be appreciated. TMC7101A master cylinder to proportioning block rear TMC7101B master cylinder to proportioning block front TKT7204A master cylinder to front brake T TKT7204B front brake T to left front TKT7204C front brake T to right front TKT7204D master cylinder to rear brake junction TKT7204E rear brake junction to rear junction
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 01-20-2022 at 09:03 AM. |
Re: The Right Stuff 71-72 Disc brake line kit help
I purchased this same kit, and I had the same frustration. it would be so easy for them to label the pieces. I ended up just comparing what was pulled off of the truck to what I had in the box, it was pretty self explanatory after doing some comparisons. I never thought to look if I could purchase single brake lines, if that is the case... the TK#'s may be labelled as to where they go on the manufacture's website???
FYI - my rear axle lines did not fit well, I had to manipulate them quite a bit in order to get the fitment I wanted. I read a couple other reviews and it was also fairly common that the front lines coming across the back of the crossbar of the frame needed some help. I had a 73+ front crossbar, so I was hosed regardless. Good luck, I hope it goes smooth for you. I have a fair amount of pictures in my build thread of the brake line install on a bare frame around post #40... and after. It might help?
I’ve updated this with what I believe is correct. Lines with protective spring wrap are closest to the master cylinder.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
