03-19-2017, 03:56 PM | #1 |
Vent door?
Does anyone know if this vent door is even available at all anywhere or if the seal can be repaired or replaced ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
03-19-2017, 04:46 PM | #2 |
Re: Vent door?
I hear the seals are available.............or you can buy new vent doors. As I recall, other than the originals being painted, there's no difference between the original doors what I purchased from Classic Heartbeat.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-19-2017, 05:02 PM | #3 |
Re: Vent door?
My daughter sent for this catalog for my truck.I have a 1967 Chevy.The same vents that you have.Here is the catalog to send for "1960-1972 Chevrolet-GMC Truck. http://www.truckandcarshop.com/
On page 51 is the pr of fresh air vent valve seals at $7.00 pr.67-72.Part #67-05313.
Barbara Jean |
03-19-2017, 06:59 PM | #4 |
Re: Vent door?
I found them in the catalog for classic industries, 5.99 for the pair. I assume you have to drill the rivets out as the seal is sandwiched between the two pieces. Has anyone ever replaced these seals ?
03-19-2017, 07:03 PM | #5 |
Re: Vent door?
http://www.classicindustries.com/pro...rts/iv672.html
Seals for 5.99 or http://www.classicindustries.com/pro...rts/14839.html They do have the complete unit for 44.99
03-19-2017, 09:26 PM | #6 |
Active Member
Re: Vent door?
Don't sweat this I just did it with mine it's easy all you had to do is drill out the rivets get your new seals and aline the seal free pre drill the rivet holes through the seal. Just do one at a time and now is the time to clean them up and paint. Doug
03-20-2017, 06:24 AM | #7 |
Re: Vent door?
So did you rivet them back together ?
03-20-2017, 01:55 PM | #8 |
Re: Vent door?
I took mine apart, just drill out the rivets, and while you're at it you could clean them up and paint them. It's a very easy thing to do. I pop riveted mine back together since they are out of the way.
03-20-2017, 02:18 PM | #9 |
Re: Vent door?
I did mine years ago and used some 1/8" thick red silicone gasket material that was soft and pliable.
I drilled out the rivets and replaced them with screws and nylock nuts. I used the old gaskets to get close on the cutout for the gasket material. It was more about time than cost. The cost was like $15 for the material, then I had to cut out the patterns and drill the rivets and bolt it all back together. Probably a couple hours for both, taking my time.
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
