Old 02-27-2011, 02:09 PM   #1
Hardesty454
Hardesty454's Avatar
Jolene
Ok guys,
I've been meaning to start this for a while but can never get around to it.
I bought this one about 5-6 months ago and its been rough, to say the least. Picked her up for $4,500. good deal! until she broke down on the drive home, on I-5, with no in state tags - and got towed. I spend another oh $800 or so between the impond fees and registeration so far. Another @200 to have her towed home.
Anyway, Here is the specs so far:
71, Short step.
402 - Edelbrock intake and 750 carb. fresh strip and painted
new torque converter (1900 stall)
aftermkt headers (wrong size for body of truck and bang against frame, will be replaced soon)
3" straight pipe exhaust to magnaflow mufflers, turndowns at rear bumber.
2" cowl hood
aftermkt grille assembly (soon to change to large mm bars)
20" rims
I have rewired the entire engine compartment with rolls of wire, electrical tape, connecters and shrink wrap. tore distributor down and rewired the inside of it as well.
The wiring to the tail lights were snipped with someone (P/O?) inset the brake lights into the fenders and needs to be redone proper.
Eventually When I do the frame off I will just buy wiring harnesses so I dont have to redo it again but all this will work for now (my lady wants a boat this summer and we need some power to pull it)
PS. sorry I took all these with my cell...
Hardesty454 is offline   Reply With Quote
Old 02-27-2011, 05:22 PM   #2
Hardesty454
Re: Project: Jo, The other girlfriend.
So you see that fender?
I cannot for the life of me get it straight. Ive tried everything. I even posted a thread about it and tried other suggestions to no end. Ive never wanted to pay anyone to help but I think I might be getting to that point.
Old 02-27-2011, 05:38 PM   #3
low&slow
You could shave down that inner mount up by the grill and pull it in slightly. That would pull the whole fender over.
low&slow is offline   Reply With Quote
Old 02-28-2011, 07:43 PM   #4
Hardesty454
Does anyone know a body man in the nor-cal area (chico to redding) that can set the allignment up for me??
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Old 02-28-2011, 09:53 PM   #5
Hardesty454
So I havent been able to do much lately (been sick and got a new puppy)
But I though Id put some picture up of what Im working with. Essentially everything is how it came except the motor. I tore that out when I first got the truck and cleaned it up a little bit.
Rob
Old 02-28-2011, 10:02 PM   #6
Hardesty454
a few more...
Rob
Old 02-28-2011, 11:22 PM   #7
Hardesty454
how about these too
Rob
Old 03-02-2011, 01:37 PM   #8
butternut1972
butternut1972's Avatar
Looking good. I love big blocks, should be a good boat puller.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 03-05-2011, 06:22 PM   #9
Hardesty454
Ok, so been super busy lately with work. March is rediculious with home building and remodeling. I did manage to relocate the fuel pump to the frame rail (exterior rail below the cab) and do a little work on the bed. I ran new plumbing on all the fuel lines (high pressure rubber) and was amazed how cheap harbor freight has insulated mounting brackets, used for the new trans lines and high pressure fuel lines.
Here is some recent photos of what was under the plywood in the bed....
Rob
Old 03-07-2011, 10:54 PM   #10
Hardesty454
Ok, Got the old rotted wood completely out. Cleaned up the rear end. Now have the front end almost completely put back together. I have to remount the bumber and then tun the engine and shes back on the road!
Rob
Old 03-07-2011, 11:23 PM   #11
lowdown72
lowdown72's Avatar
hey its lowdown heres apic of my truck with the drop on it
72 c-10 67 clipped 327 th400
lowdown72 is offline   Reply With Quote
Old 03-07-2011, 11:34 PM   #12
Hardesty454
VERY NICE!!!
Yea I was wondering! but def looks great. Where did you pick your suspension up from might I ask, Ive been looking at a kit on POL for about $600.
Rob
Old 03-07-2011, 11:54 PM   #13
lowdown72
lowdown72's Avatar
its all mcgauphys 5 in rear springs 1 in front spring an 2.5 in drop spindle got most of it from manes truck part got about 500 in it all
Old 03-07-2011, 11:55 PM   #14
lowdown72
lowdown72's Avatar
sorry i gotta get better pics this is the most recent pic satin red an black
Old 09-21-2011, 08:44 PM   #15
Hardesty454
Ok, So I am finally back working on this truck (moved so Im commuting to work, but will be moving so Ill have more time to work on it). But I went ahead and ordered a fuel tank relocation tank from LMC. Was soooooo excited when I came home to a nice brown box on the front porch. Went to pick it up and the box pulled right off the top. UPS dropped the tank, tore the box and dented the new tank and mounting brackets. Soo Disappointed. Filed a claim with LMC and they should be sending me a new one.
Rob
Old 02-24-2013, 10:43 AM   #16
RRC
RRC's Avatar
Any updates???
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 02-24-2013, 01:38 PM   #17
Hardesty454
Lots! No one was really commenting so I figured no one was too interested. Since my last post;
Gas tank in bed, all new fuel lines. New mechanical pump. Bed completely torn off and apart. Welding up stake holes currently. Removed old a/c system and patching for a vintage air in future. Dash completely apart right now, cleaning up wiring and replacing what's needed.
Lots an lots being done! Pics available if requested!
Rob
Old 02-24-2013, 03:17 PM   #18
RRC
RRC's Avatar
Hi I'm no one...and I'm interested!!! Sounds like its coming along
Rocky Lake Kustoms
Russ
Old 02-24-2013, 03:33 PM   #19
Hardesty454
it sure is. Just hard to find time sometimes. Thank you for the interest! Ill go and see what pics I have saved and see if I cant get some up to date here for ya!
Rob
Old 02-24-2013, 03:46 PM   #20
RRC
RRC's Avatar
I hear you , between work , kids and life in general time is hard to come by.
Rocky Lake Kustoms
Russ
Old 03-02-2013, 09:13 PM   #21
Hardesty454
Going to try and update some pics via my iPhone
http://i.imgur.com/Dv79vRi.jpg
http://i.imgur.com/k1EKpAU.jpg
http://i.imgur.com/KoJrAgI.jpg
Rob
Old 03-02-2013, 09:16 PM   #22
Hardesty454
[Img]http://i.imgur.com/KoJrAgI.jpg[img]
Rob
Old 03-02-2013, 09:19 PM   #23
Hardesty454
Rob
Old 03-02-2013, 09:19 PM   #24
Hardesty454
It worked!!!!
Rob
Old 03-02-2013, 09:22 PM   #25
Hardesty454
Rob
