10-25-2011, 08:03 PM | #1 |
? Will '73, mid/late '70's 8 lug wheels fit on my 8 lug '69 C20 Suburban?
I was at the junk yard the other day and saw a '73/mid/late '70's Chevy or GMC 4x4 and am wondering if the 8 lug wheels off that will fit on my '69 C20?
Thanks for the feedback and support. Chris '66 GMC Custom Deluxe Suburban '69 Chevy C20 |
10-25-2011, 08:05 PM | #2 |
Re: ? Will '73, mid/late '70's 8 lug wheels fit on my 8 lug '69 C20 Suburban?
I don't know the exact year of the truck I saw, but I do know it was a '73 and later. It wasn't in the '80's as far as I know.
Thanks, Chris '66 GMC Custom Deluxe Suburban '69 Chevy C20 |
10-26-2011, 06:17 PM | #3 |
its all about the +6 inches
yes and no.
The lugs on your truck are 1/2 inch, the ones off the later truck are 6/16ths. (starting in 71) However, the taper on the lug nut is the same, and the lug nut will not bottom out on the hub. So it will in fact hold the wheel correctly on the hub. I know this becouse I've been running like this since '05 with zero issues. |
10-26-2011, 10:52 PM | #4 | |
10-27-2011, 11:51 PM | #5 |
Too many projects
The only problem you could run into is with the hub diameter, as I picked up a set that fits my front axle and not the rear, so a quick tape measure of you hub/axle flange and a check of the junkyard wheels will avoid that.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
10-28-2011, 01:30 AM | #6 | |
Chris '66 GMC Suburban '69 C20 |
10-29-2011, 06:07 PM | #7 |
Too many projects
Yeah, most of the guys I work with in SoCal have no clue what a Zamboni is, but I go home (the Dakotas) and tell someone that I used to run a Zamb and it's like I'm a celebrity.
10-29-2011, 06:18 PM | #8 |
11-24-2011, 05:45 PM | #9 | |
I met him once. |
