Old 01-06-2018, 09:53 AM   #1
Bob252
1993 chevy Silverado 4.3l xcab c1500 low heat problem
My heater barely works but my temp is 195° the heater hoses seem to be at about the same temperature. No over heat problem present. Coolant level is good. But the heater just won't blow hot. This has been a problem for years but lately the temperature outside has hit record lows. Please help. 😩😩😩😩😩😩😩😩
Bob252 is offline   Reply With Quote
Old 01-06-2018, 11:25 AM   #2
b454rat
Re: 1993 chevy Silverado 4.3l xcab c1500 low heat problem
Heater core is prolly plugged. Pull lines off, blow air thru the return side of the core.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 01-06-2018, 01:11 PM   #3
Bob252
Angry Re: 1993 chevy Silverado 4.3l xcab c1500 low heat problem
Did that. No change. Still only luke warm air coming out.
What mechanisms makes the cold air hot?
If there is a door that controls this. Where is it on a 1993 chevy truck?
Old 01-06-2018, 04:24 PM   #4
b454rat
There is a door in there that controls air flow. Not sure how it works or where it is. Guess I've been lucky with the pre-95s that the heat works lol.
Old 01-06-2018, 07:07 PM   #5
mountie
mountie's Avatar
There is a door to allow heat to enter cab. located, sort of below / right side of radio. access by removing glove box..... to left of glove box opening....
Also ...maybe your heater core is covered with leaves & junk. The stuff that wiggles it's way down from the vent, at bottom of windshield.
( When I replaced my A/C, I found my heater core covered with crap )
( My '88 Sierra )
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 01-06-2018, 10:04 PM   #6
ninety6
not really a lot to getting heat --- suggestions above will hopefully get you going. Its going to be either not enough hot coolant getting to/through the heater core (bad t-stat or clogged core or line), or the air going through the vents isn't going across the heater core due to a blend door issue, or as suggested, maybe even leaves!
ninety6 is offline   Reply With Quote
Old 01-15-2018, 11:35 PM   #7
diveplane
called actuator flap controls all 3 modes in vent, sometimes the mechanism sticks ,some wd40 does the trick.
like someone mentioned heater core could be plugged up, or a hose but that in return would over heat your truck as well.
diveplane is offline   Reply With Quote
Old 01-15-2018, 11:40 PM   #8
diveplane
my 94 this flap unit is drivers side under dash.
