11-17-2004, 04:32 PM | #1 |
What do we get for $10?
Superwinch transfer case conversion
Just wondered if anyone had any experience with the superwinch 203 part time conversion set. Seems like I've heard people rip on it, although I've never heard why. I'm getting ready to swap in a case with that setup, and if I need to, I'd rather switch to something else now.
Thanks guys Joe
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ) |
11-17-2004, 07:05 PM | #2 |
I've had a Warn conversion in mine for many years and have had no porblems.
11-17-2004, 08:00 PM | #3 |
Is yours the whole shaft kit or the one where you just replace the "spider" type gears?
Joe
11-17-2004, 08:12 PM | #4 |
It had the 4 little spider gears in it. I used to be pretty hard on the truck. Back then I think the only company that made the shaft type was someone like Borg Warner and they where like buying a whole transfer case. Very expensive.
11-18-2004, 12:44 AM | #5 |
huh ???
When I had my 74 Blazer, I had put the Mile Marker kit in it. It was the one like Mudder has with the spider gears. I never had a bit of trouble with it and it even outlasted an engine and transmission...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
11-18-2004, 12:59 AM | #6 |
Mine may have been the mile marker...... Long time agao.
11-18-2004, 11:17 AM | #7 |
I had the mile marker kit in the 203 that used to be in my truck. Never had any problems with it and I did wail on it a few times......that would be where I put my money. I do however like the superwinch hubs......they have held up to a lot of abuse!
The Devil 1983 ONE TON 454/400/208 11" of lift on 44's |
11-19-2004, 06:01 PM | #8 |
Mike
I was also told to stay away from the superwinch set-up.I have the mile marker kit in my 203.here is the link on installing either MM kit...http://www.coloradok5.com/milemarkerpt.shtml
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
11-19-2004, 08:23 PM | #9 |
I appreciate the help guys. Thanks a bunch!
Joe
