Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-05-2017, 11:27 PM   #1
Another 72
1967 front clip on 1972 K5 Blazer
This seems like a pretty common swap so is there a good detailed thread or tutorial? I'm trying to avoid bolting everything together only to dismantle it again (or damage parts) because I left something out. The search function helped me figure out that I needed to replace the front clip to get the sloped hood, but it's not proving helpful at providing small details (i.e. inner fender reinforcement/brace). I've gathered a 67/68 hood, grill, core support, and inner fenders as well as 1967 outer fenders. I know I also need a hood latch.
Thanks,
Rob
Rob
"1967 Wanna Be" 1972 K5 Blazer
Another 72 is offline   Reply With Quote
Old 09-06-2017, 06:43 AM   #2
jaros44sr
jaros44sr's Avatar
Re: 1967 front clip on 1972 K5 Blazer
The only problem I ran into is that the 67-68 core support was set up for two radiator, had to change lower mounts and cut a relief for my four core alum.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-06-2017, 07:39 AM   #3
jaros44sr
jaros44sr's Avatar
cuts to clear radiator
[url=https://flic.kr/p/XS1yDY]20170906_072101
SAFETY FIRST
AS usual, off topic
Jim
Old 09-06-2017, 07:23 PM   #4
Another 72
Jim,
Thanks for the heads up. I checked out your build (~page 14?) but got the photobucket error instead of seeing images. Seems like your pieced together 67-68 front clip more or less bolted right on, so that's a good sign. Your build thread is HUGE! Do you know which pages deal with the front clip replacement?
Thanks,
Rob
Rob
Old 09-07-2017, 09:31 AM   #5
jaros44sr
jaros44sr's Avatar
Originally Posted by Another 72 View Post
Jim,
Thanks,
Rob
sorry for the photobucket SNAFU, but I can take new pics of any area you have in question. good luck with your build.
I used a repro grille, and you will want to take out the rivets for the grille surrounds as the are not painted behind them, just a heads up if you go this route
sorry my build is soooo big
Also, the core support bushings will give you fits, since your frame bracket is set up for 72, but your core support is 67-68, buy both bushing and fit as needed, or change the bracket on the frame. Holes are a different size. You'll see the effect of this when you mount the fenders and the gap between the fender and door is off
Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 09-07-2017, 11:57 PM   #6
Another 72
Jim
Thanks, Jim.
I was interested in your thread because you've already done what I want to do. If memory serves me correctly your build thread is 100+ pages. I found some front clip discussion on page 14 or so, but I don't know if there's more or what the sequence of the build was.
Do you have pictures of the rivets and grill surrounds? I think I've read that the 67-68 core bushing is shorter than the 69-72 - is this what you're referring to? I was thinking of using a temporary spacer or even washers. What did you do?
Your advice is greatly appreciated, as would be any related images you can provide.
Rob
Rob
Old 09-08-2017, 04:55 PM   #7
jaros44sr
jaros44sr's Avatar
Thanks, Jim.
Rob
this the core support mount, I used the 72, I would modify the mount by welding in a large washer to reduce the hole size
[url=https://flic.kr/p/XfY1W7]20170908_1105
SAFETY FIRST
AS usual, off topic
Jim
Old 09-08-2017, 04:57 PM   #8
jaros44sr
jaros44sr's Avatar
67-68 core support
[url=https://flic.kr/p/XVLjKE]20170908_110407
SAFETY FIRST
AS usual, off topic
Jim
Old 09-08-2017, 09:15 PM   #9
Another 72
Jim,
Great, looks like I got the right core support after all. In the picture your core support looks like its hanging off one side of the bushing - am I seeing that right?
Rob
Rob
Old 09-08-2017, 09:16 PM   #10
Another 72
By the way, did you POR your core support? That thing looks smooth as glass!
Rob
Old 09-08-2017, 10:04 PM   #11
jaros44sr
jaros44sr's Avatar
Jim,
Rob
No, it is more front to back angle you're looking at
SAFETY FIRST
AS usual, off topic
Jim
Old 09-08-2017, 10:06 PM   #12
jaros44sr
jaros44sr's Avatar
no, that is EPD. you have to remember, I am still in mock up
SAFETY FIRST
AS usual, off topic
Jim
