06-21-2018, 08:09 AM | #1 |
Door Hinge Inner Brace
I am about to tack in my new lower Jam piece for the drivers side door. I noticed that the new patch panel doesn't have the inner bracing. Do you guys just weld nuts on the inside of the new panel or do you get the brace out of the old piece and tack it in ? Any help would be appreciated.
06-21-2018, 10:01 AM | #2 |
Re: Door Hinge Inner Brace
I welded nuts on, I didn't need to have "original" as to this part, but do what is easiest and functional for you. I tacked 6 times around each nut for strength.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
06-21-2018, 01:57 PM | #3 | |
Posted via Mobile Device |
