03-20-2021, 01:50 PM | #1 |
swap blocks for shorter springs?
My '68 c10 swb has -2" springs and 2" blocks in the rear. This configuration allows me to run stock shocks in the stock locations. It seems to handle decent enough and I can still haul my motorcycle.
Is there any advantage in switching to shorter drop springs with no blocks and relocated drop shocks?
Insert clever text here: |
03-21-2021, 04:34 PM | #2 | |
Re: swap blocks for shorter springs?
Relocating the shocks for better geometry or positioning would be an advantage.
03-23-2021, 12:33 AM | #3 |
That's good enough for me. Thanks SCOTI
03-24-2021, 12:47 PM | #4 |
Ride the motorcycle?? problem solved
03-24-2021, 08:23 PM | #5 |
True
Unfortunately, motorcycles need retrieved sometimes. Moot point anyway. I just ordered shorter springs for my "incredible shrinking truck". I think I'll see what it looks like with a 3.5/6 drop ...WTH is wrong with me?
03-24-2021, 10:35 PM | #6 |
Rear bags vs. coils would be a good choice as well. Adjust as needed to keep the ride height consistent loaded or not & provide good ride quality either way.
