Old 07-05-2019, 06:09 PM   #1
70inbville
swap harness pin question
hey all,
just a question about the vss wires on green connector pins 20 and 21. which wire would a person connect to a Dakota digital 128,000 pulse generator? sen-01-128 instructions have three wires red(power for the sensor) black(ground) and white which speed input to pcm. which wire does it go to, pin 20 is low signal and pin 21 is high signal according to the pinout from lt1swap. thanks for any input.
Chip
70inbville is offline   Reply With Quote
Old 07-05-2019, 07:52 PM   #2
ls1nova71
ls1nova71's Avatar
Re: swap harness pin question
I dont think high and low make any difference in a VSS signal. The low is a ground signal and high is the sensor signal so I would go with the high.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-05-2019, 08:27 PM   #3
70inbville
Thank you for the info nova!
