Old 06-02-2015, 09:14 AM   #1
oldblue92
oldblue92's Avatar
Turn Signals not working!
Hi guys its been a min since my last post but I need some help. I recently bought a 1989 silverado 4x4 single cab. the other day the turn signals stopped working. The Hazards work fine and i can here the relay clicking. But even when I click the indicator lever the light does not appear on the dash or outside lights. Any advice in the right direction would be great thanks a bunch guys!
oldblue92 is offline   Reply With Quote
Old 06-02-2015, 02:37 PM   #2
green_grenade
green_grenade's Avatar
Re: Turn Signals not working!
I would try and find the wiring down in the steering column and see if you are getting anything out of the switch at all.
green_grenade is offline   Reply With Quote
Old 06-02-2015, 09:35 PM   #3
Cape Codder
Cape Codder's Avatar
The turn signal flasher could be bad.
Cape Codder is offline   Reply With Quote
Old 06-04-2015, 10:30 AM   #4
oldblue92
oldblue92's Avatar
Are the Hazard's and turn signals on the same relay?
Old 06-04-2015, 03:44 PM   #5
Powar
Powar's Avatar
There are two flasher modules. One runs the hazards and one runs the turn signals.
Powar is offline   Reply With Quote
Old 04-10-2016, 07:46 PM   #6
harricanfloyd
men, we need to follow up with actual problem fixes.. We don't know if you got them working or not lol
harricanfloyd is offline   Reply With Quote
Old 06-10-2019, 02:57 PM   #7
Suburban Steve
Suburban Steve's Avatar
I know this is an ANCIENT post BUT it is exactly what my 92 2dr Blazer/Tahoe is doing Hazards are fine... No blinkers... no click no indicators etc.... someone says 2 different flashers.... where is the flasher for the blinkers?
Thank in advance for any response that is helpful.
Suburban Steve is offline   Reply With Quote
Old 06-10-2019, 05:36 PM   #8
ChevyTech
The turn flasher is in the bottom left corner of the Convenience Center, which is just to the right of the park brake assembly.
