07-15-2019, 06:06 PM | #1 |
18x9 front and rear?
Is it possible to run a 18x9 front and rear on a 70 c10? Likely running 275/40r18 if a 18x9 will fit what backspacing? Tried searching but couldn't find anything
Truck is currently 3/5 drop.. Bed is off as frame is a about to be notched. Will be a fleetside no tubs or bedfloor. |
07-15-2019, 06:28 PM | #2 |
Re: 18x9 front and rear?
18" X 9.5" 5.25 backspace. Rear tires are 275/55 R18. Front tires are 255/55R18
2.5" drop spindle front with a 4" drop in the back. |
07-15-2019, 06:29 PM | #3 |
07-15-2019, 06:34 PM | #4 |
Yes, they are the same. I went with a slightly smaller front tire because it did rub on the inner fender a touch. The only thing close on the front are the brake lines at full lock. I wrapped those with wiring loom just in case but no issues.
The wheels are the Rambler U111 if that helps. Link below....scroll down a bit and click on the 18" tab http://us-mags.com/rambler-u111-w-6133.htm |
07-16-2019, 03:51 PM | #5 |
07-16-2019, 04:15 PM | #6 |
I plan on running a set of 18x9 with 275/40r18s front and rear with a 5 backspacing both front and rear as that's my only option for these wheels. Think I'd need a spacer on the rear to get it closer to the fender or do you think it'd look fine?
07-18-2019, 09:13 AM | #7 |
Spacers won't be required, but the fleetside has rather large wheeltubs, so you may want to space them a bit for a desired look.
