01-27-2004, 01:46 AM | #1 |
dana 44 parts interchangeable?
Can we use ring and pinions or carriers out of ford dana 44's in our housings?
(i.e. 3.50 gears)
Bob |
01-27-2004, 08:01 AM | #2 |
user # 2756
I don't think so the dana 44's in fords are high pinion axles. Assuming you mean the front axle as most fords had the 8 or 9" rear end.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
01-27-2004, 03:06 PM | #3 |
yes talking front ends
Jeeps, dodges, fords, chevys, etc used dana 44 fronts during same time period.
I assume there are different widths but are many parts interchangeable?
Bob |
01-29-2004, 11:59 AM | #4 |
All 44 parts are interchangable except ford front gears as they are reverse cut, and the early jeeps that were coarse spline spiders. I think there are 3.54 standard cut gears available-- wagoneer if I remember right
01-31-2004, 11:47 PM | #5 |
horsepower junkie
ya many waggoneers have the 3.54s...and a standard pinion..
67 short wide box,350/700r4/3.73posi 71 olds cutlass "S" mom bought new..12.30s@113MPH |
