Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 10-12-2021, 06:35 PM   #1
72 DIRTY RAT
72 DIRTY RAT's Avatar
72 Suburban rear A/C unit
Hi Guys, I need opinions!
My 72 A/C is all original. The fans work front and back, but the back fans are way to noisy! It needs some minor other work to get operational but I am thinking of getting rid of the rear unit (it’s so bulky) and buying/retrofitting a whole new updated A/C system. That means front air only!
The question is whilst the new systems are great, would they cool the whole cabin?
*1972 454ci Burb, C20 3/4T, T700, 2WD
*1969 540ci Vette, 540ci Aluminum BB,755 BHP & 734 LbFt torque, No NOS, No Forced induction! Just BIG CUBES
72 DIRTY RAT is offline   Reply With Quote
Old 10-13-2021, 12:45 AM   #2
BAD1916
Re: 72 Suburban rear A/C unit
I don’t have experience with a front only setup so I can’t comment on that. However, if your truck has been insulated well I would think that it would cool well.Hopefully others will chime in with real world info.
BAD1916 is offline   Reply With Quote
Old 10-13-2021, 04:37 AM   #3
72 DIRTY RAT
I have put new insulation everywhere, plus I very rarely use the back seats.
Old 10-28-2021, 07:31 AM   #4
BigBird05
72 Dirty Rat, is your A/C unit roof mounted? I have a floor mounted unit listed in the for sale section with a picture. I don't know if the fans are the same or not.
BigBird05 is offline   Reply With Quote
Old 10-28-2021, 12:18 PM   #5
FLYNAVY30
I have an original front and rear A/C set up, although it was not operable when I purchased my truck. I replaced the front unit with a vintage air set up. I can assure you, it will not cool the entire truck. Its comfortable in the summer with the air blowing on you in the front, but the middle and rear does not get comfortable. Just too much glass and too much space. At some point I will attempt to either integrate the factory rear A/C with the vintage air, or replace it with a second vintage air system.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
FLYNAVY30 is offline   Reply With Quote
Old 11-22-2021, 03:02 PM   #6
19Suburban69
I've got dual vintage air on my '69 C20. Recently did LS swap and used stock compressor. works just fine. Winter I use rear heat because I don't like front vents blowing in my face with heater.
1955 Chevy, 2 dr post, my first car
1969 Chevy C20 Suburban, 6.0 LS w/4L80
2001 Silverado Z71, 5.3 extended cab
19Suburban69 is offline   Reply With Quote
Old 12-18-2021, 12:54 AM   #7
72 DIRTY RAT
Thank you for all the replies! I ended up just pulling the rear system out, I will eventually get vintage air for the front, I really only need the front air anyways!👍👍
Old 12-18-2021, 09:39 AM   #8
FLYNAVY30
Any chance you could give us some additional info on where/how you mounted the second vintage A/C unit and how the plumbing works?
Thanks!
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 01-28-2022, 12:09 AM   #9
WannaBe68
WannaBe68's Avatar
At least here in Texas - the 2nd and 3rd rows can become pretty warm for the boys. But my wife and I are comfortable with the front only Vintage air system :-)
I do, however, have a complete rear system that I plan to install this year some time to give them a break during our summer road trips.
WannaBe68 is offline   Reply With Quote
Old 01-28-2022, 01:45 AM   #10
19Suburban69
Thanks!
Previous owner bolted generic vintage air blower unit to roof then built box around it. Freon and wiring run down right rear corner thru floor and along frame to front.
Old 01-28-2022, 10:45 AM   #11
polishspy
Thanks!
So this is what i had put together to run an under dash front unit and s small unit under the front seats. The plumbing has two selenoids to feed each of the units and 2 set of dryers.
vintage air part numbers - 751170 (evaporator), 521171 (hoses), 021567 (condenser), 110061 (fittings for compressor)
Monster condenser, PN 037030-OVR
Sanden 709, PN 04709-VMA
polishspy is offline   Reply With Quote
a/c, airconditioning
