Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 09-18-2016, 01:24 AM   #1
Leonard60
2015 crappy headlights what to do??
Ordered my 2015 GMC Sierra in 14 2500 HD and the lights are terrible. Gm upgraded the lights after I complained about them. That was a waste of time so I went to LEDs first set lasted almost 1 year and they burnt out. Gm replaced these lights on warranty. They worked ok still not the greatest but I guess tonight on my way home these new head lights (less than a year old) drivers burnt out. I need to fix these once and for all. I'm not sure this is the forum to ask on but I thought there's a lot of knowledgeable people on here so thought its sure worth a try. So can anyone here have some answers. I've searched the net and there seems to be a lot of opinions out there but I haven't seen anything that seems to be the sure fired answer.
Leonard60 is offline   Reply With Quote
Old 09-20-2016, 01:14 PM   #2
Tynee
I miss this truck.
Tynee's Avatar
Re: 2015 crappy headlights what to do??
No solutions for you, but I'm in a similar boat with my wife's '07 Acadia. I'm not pleased with the blue tint to the light that the factory lamps emit, and the lenses are pretty hazed, so I'm looking for a good replacement that will fix both of those issues.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 12-15-2016, 07:03 AM   #3
dennislbrooks
dennislbrooks's Avatar
How did GM update your 2015 2500HD headlights? I know the Silverado got a bad headlight review but is your complaint on low beams or both. I may just try adjusting the low beams up if possible. I do not have a complaint on high beams.
Also side view while making sharp turns could be improved. Maybe an LTZ has side turns lights --dunno, I have a WT.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 12-15-2016, 07:22 PM   #4
Cali72K20
Cali72K20's Avatar
There is a TSB for that issue: TSB #PIT5374
I thought I was just going blind and I turn on the fog lights at night. I have a 1500 Sierra sold as a 2015 but built in 2014.
http://www.gmcproblems.com/trends/terrible-headlights/
Cali72K20 is offline   Reply With Quote
Old 12-15-2016, 08:34 PM   #5
dennislbrooks
Ok, I may not have as much a problem or at least not as noticeable to me. I ordered my Chevy silver ice 2500HD Duramax 4wd reg cab long bed with convenience package and NO snow plow prep on March 30, 2015. It appeared they were not going to build it but I finally received it on July 30, 2015. It may be near one of the last ones built and have the upgrade already.
Old 01-26-2017, 03:59 PM   #6
BrianG
BrianG's Avatar
I have a 2015 1500 Sierra and the Headlights are horrible. I sure wish GM could come up with a real fix to this issue. My dealer has sort of just blew me off with this. I guess maybe I should try going to another dealer, but I'm sure they would just pull up my vehicle and know I've already complained about it.
BrianG is offline   Reply With Quote
Old 02-03-2017, 02:01 PM   #7
biketopia
Search over on the duramax forum, a lot of guys over there have posted different mods they've done on their LML equipped trucks to help out. *The LML is the duramax engine code for the 11-16 HDs*
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-25-2017, 11:03 PM   #8
RickDeVon
RickDeVon's Avatar
My 11'Chevy crew 2wd has great headlights...thought the newer models would have even better lights...
71 C10 I6 250 TH350 power steering and power breaks...
RickDeVon is offline   Reply With Quote
Old 07-02-2017, 10:23 AM   #9
gmc 2500 4x4
thanx Cali72K20
gmc 2500 4x4 is offline   Reply With Quote
Old 07-05-2017, 11:57 PM   #10
Cali72K20
Cali72K20's Avatar
Originally Posted by gmc 2500 4x4 View Post
thanx Cali72K20
Your welcome, my headlights still suck and now I run the high beams at night.
Casey
Old 07-13-2017, 07:24 PM   #11
Cali72K20
Cali72K20's Avatar
I took mine in today and this is the repair they are going to perform to fix the lighting issue. Service writer said they are going to change the bulbs and then re-align the headlight assemblies. Hopefully this fixes the dim headlights.
http://sandyblogs.com/techlink/?p=4507
Old 07-19-2017, 11:47 PM   #12
jamie72
jamie72's Avatar
cali post up if this helps.. i just bought a 14 gmc, and love it till it gets dark...
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 07-20-2017, 07:26 PM   #13
64krusty
64krusty's Avatar
My 2015 Denali's headlights sucked, I took it in and had the TSB upgrade done, still sucked, I just traded it in on a 17 GMC SLT, the new LED headlamps are really good, anyone with a 14 or 15 that wants good lights may have to do the LED swap
64krusty is offline   Reply With Quote
Old 07-31-2017, 01:53 PM   #14
Cali72K20
Cali72K20's Avatar
It made it a lot better, I think the LED upgrade like the 2016 models would be the best fix.
