Old 08-18-2011, 09:10 AM   #1
mcafeeswelding
54 gmc -mustang II front. question
I have a 54 gmc 100 pick up that i am wanting to put a mustang II front end under.From the information that i have gotten from the numerous companies that sell the aftermarket kits that axle center is very critical when installing these. my question is when you measure for your axle center,you are measureing to the center of the axle or the center of the hub? when you get above the axle and look down on it the spindles angle back towards the cab a little. Just want to get the correct measurement. have the frame with cab still attached sitting on jack stands. am open to options on obtaining the correct measurements. would rather not measure to existing axle it is in rough shape concerned that it may be tweaked from sitting for so long over to the passenger side because of no rim on it. thanks .
mcafeeswelding is offline   Reply With Quote
Old 08-18-2011, 02:03 PM   #2
solidaxel
solidaxel's Avatar
Re: 54 gmc -mustang II front. question
I use the King Pins center and transfer that to the frame
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
