Old 10-18-2010, 02:07 AM   #1
BIG V
pick n pull chalet ....
as seen at pick in pull
BIG V is offline   Reply With Quote
Old 10-18-2010, 07:32 AM   #2
Davidmichael
Davidmichael's Avatar
Re: pick n pull chalet ....
awe. that's a sad sight.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 10-18-2010, 08:47 AM   #3
Pop's C-10
Pop's C-10's Avatar
yes it is
Pop's C-10 is offline   Reply With Quote
Old 10-18-2010, 09:41 AM   #4
Woogeroo
I wonder if you could pick the top off... or if they'd let you.
I know it comes off, but it's a job as I understand it. They probably wouldn't let you in with the equipment you'd need.
Does anyone know if they used the standard blazer frame for those? Then added a extended portion? Did they use a short bed chevy truck frame? I ask because the rails stick out under that bottom section on the back a bit.
-W
p.s. read more about it:
http://www.blazerchalet.com/
Woogeroo is offline   Reply With Quote
Old 10-18-2010, 11:38 AM   #5
sixshooter798
Desert Rat
sixshooter798's Avatar
Thats a damn shame.
sixshooter798 is offline   Reply With Quote
Old 10-18-2010, 12:50 PM   #6
BIG V
its sad, i wanted one of those for years before i got married and children
Old 10-18-2010, 05:23 PM   #7
79gmcclassic
79gmcclassic's Avatar
that junkyard would prolly sell it for dirt cheap! if i was by u i would scraped up the money as fast as i could!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 10-18-2010, 05:23 PM   #8
79gmcclassic
that junk yard would prolly let you get that dirt cheap! if was by u i would of grabbed that already no matter waht!
Old 10-18-2010, 11:34 PM   #9
Number21
Number21's Avatar
Oh, the horror!
I'd buy it just for the VIN, it's bound to be worth something someday.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 10-19-2010, 08:42 AM   #10
68Timber
I know the pieces fit
68Timber's Avatar
Sad. I don't see enough damage to scrap it.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-19-2010, 09:30 AM   #11
It's missing the top,isn't it?Maybe it flew off and that's where the owner gave up on it.Or,someone actually raped it off for another Chalet?They were built off a normal K/5.
Old 10-22-2010, 12:08 PM   #12
77blazerchalet
former Chalet owner
77blazerchalet's Avatar
PM sent to BIG V for the SN # build date info from the plate by the back door.
Originally Posted by Woogeroo View Post
I wonder if you could pick the top off... or if they'd let you....
If the Blazer itself is in good enough shape to salvage, then guys should not separate the camper from the original Blazer, otherwise the collector value is wiped out. From all the orphaned shells-only I've seen for sale, the going rate usually always falls to $300-400. The complete vehicle (when they are in good shape) is what's valuable to collectors since these came that way from the factory. I managed to sell mine for $8500 recently (see this thread), but would have rather kept it if the economy wasn't so bad.
These were put on Blazers with slightly more heavy duty suspension (not quite enough, though), and Chinook or GM must have fabricated bumper extensions for them. These bolt on to the rear seat holes - I think - along with the standard camper shell holes, but these units are one heckuva chore to remove and really aren't free standing. A brace needs to be made to support the cabover section when they are off the Blazer. On the RPO tags in the glovebox, it will say "16T5 Chalet Camper Pkg" on the option list, but there is nothing on the VIN to say it's a Chalet.
Re-attaching flown-off roofs to these is also a horrible chore, but it could be a marvelous opportunity to perhaps adapt a Toyota Chinook roof to it and customize it so that it overlaps the walls. That's a job for an expert fiberglasser. The original design sits literally on top of the walls, and the way the water drains off the top is an open invitation to leakage inside the camper...
Former owner of Chalet #1747. Current caretaker of the very old BlazerChalet.com website.
77blazerchalet is offline   Reply With Quote
Old 10-22-2010, 12:34 PM   #13
77blazerchalet
former Chalet owner
Oh, wait, I know that one, it's SN 1022, built 11/76. One of our Chalet owners forum members checked it out several years ago near Sacramento and sent me the photo below. I'd forgotten it had the black fender flares, but that detail was what helped me locate it in my mega-spreadsheet file. Notice also the AAA decal on the back bumper toward the left above the rub strip is the same in Big V's photos.
Old 10-22-2010, 03:50 PM   #14
3r!c84
Badass
3r!c84's Avatar
side trim still looks good..
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-22-2010, 10:32 PM   #15
You are truly the Chalet sleuth!
Old 10-23-2010, 09:43 PM   #16
BIG V
thats impressive you know the truck.... How many chalets are left out there?
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
Old 10-25-2010, 11:46 AM   #17
77blazerchalet
former Chalet owner
Thanks, more just the luck of collecting photos and for sale ads. My mega-spreadsheet shows over 200 where I am reasonably sure they are still around, but I'm thinking there's probably a few hundred more out there to be discovered just like this one.
Do you have contact info for the junkyard? A couple of the guys in that area in our Chalet owners forum could probably use some parts off it, or they might get the whole thing.
Old 12-14-2010, 12:35 AM   #18
Bones_GSXR
There was just one (camper section only) on CL here. He had it listed one week as a Blazer camper shell at 800.00 then the next week as a rare Blazer Chalet at 1000.00. There are at lest two complete ones in the area as well.
Bones_GSXR is offline   Reply With Quote
Old 12-14-2010, 01:44 AM   #19
77blazerchalet
former Chalet owner
Originally Posted by Bones_GSXR View Post
..listed one week as a Blazer camper shell at 800.00 then the next week as a rare Blazer Chalet at 1000.00...
I was fortunate to catch the prior owner of that one before he sold it to the current seller, it's #1243. Haven't corresponded with the current seller, just tried to find out if he could salvage the truck part to at least maintain some of the collector value.
One of our Yahoo forum members in AK was recently selling #1054 which is unusual for having no front camper windows from the factory. Another of our Ak members was selling his #0560, but I lost track of him about a year and a half ago. Those might be the two you see in that area, but there could be others, please do snag photos of them if the opportunity is available.
Last edited by 77blazerchalet; 12-14-2010 at 02:00 AM. Reason: found one photo link...
Old 12-14-2010, 09:42 PM   #20
spudz
spudz's Avatar
I want one of these. Its sad to see it in the junk yard., Looks like it was in alot better shape a few years ago in that pic.,
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-14-2010, 09:51 PM   #21
spudz
spudz's Avatar
u seen this one., Its expensive.....but its real nice.. http://atlanta.craigslist.org/atl/cto/2090250785.html
Old 12-14-2010, 10:28 PM   #22
77blazerchalet
former Chalet owner
Thanks for the alert, I am aware of it, but I wasn't picking up this newest Craigslist link in my usual pair of bookmarked searches, maybe because he has it as 'chevy chalet' instead of 'blazer chalet'. It's owned by one of our newer Yahoo forum members, but was formerly owned by 67-72 member "Big Block", see his post about it here.
Old 12-15-2010, 09:17 AM   #23
pooods
Sure wish someone locally would save this thing! That's a shame.
John M. Ayers
pooods is offline   Reply With Quote
